Thread: Spa tripping breaker
    Jun 2014
    Thompson, ND
    33
    I drained my spa and turned it off. What I didn't know was that it automatically turned itself on after 30 minutes. It ran in cycles all night with very little water in the spa. Now the breaker trips immediately. I disconnected the different systems and it seems it may be the circ pump or the heater causing it. What could be ruined by running a spa without water?
    Re: Spa tripping breaker
    Welcome to TFP!
    The heater is very sensitive to being run without water. They pump(s) may also have failed, though that is more of a 50/50 chance thing than certain.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Sounds like there may be some damage to the pump. As pumps age, more mechanical resistance develops in the motor and wet end. Running them dry will rapidly accelerate that process. As that mechanical resistance increases, more amperage is needed to run the pump at its designated RPM. That increased amperage draw is what is tripping your breaker. My spa does this occasionally when for instance both pumps are on high and the heater is trying hard to warm the water = maximum amperage draw. It could also be the heater but the timing points to possible pump issues.
    Isolated Spa - 345 Gallons
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Have you been able to disconnect the heater or turn it all the way down / off so you can see if turning only the motor on trips the circuit breaker ??
    Solar Blanket, Well Water, Borax Added. 68
