Results 1 to 10 of 10
Thread: Best way to fix a pvc pipe leak
    Let me first start off by saying I know I should just replace the piping. However this is the piece attached to my hayward multiport valve and to replace it I would have to replace the whole valve along with several pipes that were glued into it. I tried the method of adding extra pvc cement to the joint. That worked for about a year. I tried it again this year and it's just not going to cut it. I was going to remove the glue around the joint and start fresh but looking for the best method. Thanks in advance.
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,002
    Re: Best way to fix a pvc pipe leak
    Got a picture? A lot of pool plumbing is dual-sized. You might be able to stick the bigger connector on the outside and then us a reducer to bring it back down.
    This is the valve unit. It's the side straight piece that's leaking. Not at the o ring but at where it goes into the valve body.
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    Richard320's Avatar
    Jan 2010
    19,002
    I was hoping a picture in place.
    It connects to a sand filter. I don't know what you're hoping to see.
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    Richard320's Avatar
    Jan 2010
    19,002
    Quote Originally Posted by headrec View Post
    I dunno, maybe an arrow or something showing which piece is actually leaking? If it's what I think, maybe some epoxy putty.
    http://www.lowes.com/pd_23533-138-31...ductId=3132883
    Sorry my bad, thought the text I posted was enough. Here is the pic. Obviously red arrow is the leak.
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    Apr 2013
    North OKC Area
    300
    I would try jb weld epoxy.
    Jun 2012
    western NY
    1,560
    As you have discovered, PVC cement won't cut it for a repair like that. PVC joints are made by solvent welding the two parts together. The cement used softens the material and allows both sides to "melt together. Once the solvents evaporate, the joint re-hardens. The "glue" itself has no structural strength and thus won't last long. Sand the area at the crack/leak and apply some JB weld as mentioned. Properly applied that will outlast the part it is on.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    I totally forgot about jb weld. Love that stuff. Just picked some up and will be trying that tonight. Thanks!
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
