Results 1 to 12 of 12
Thread: New quartz finish problems
    Jun 2014
    Longwood florida
    3
    Hi all, we just had our pool refinished with sunstone quartz, after a few weeks we had a lot of dark staining, the company came back to look at it and suggested adding 5 gallons of muratic acid every week for 3 weeks and continue brushing, after doing this it was better but we continued to add 3 gallons a week for a further 3 weeks and still brushing daily, it looks fine now but I'm noticing white clouding while brushing and the surface feels rough and loose to touch, also the chemistry is way off, does anyone know if this could be damaging the new surface? Or any suggestions on what to do next? Thanks
    Casey's Avatar
    SW PA
    10,461
    Re: New quartz finish problems
    Welcome to TFP.
    I am not as familiar with these finishes as some are but I would URGE you to continue on as the company instructs to protect the warranty and someone with more experience will be along to help you.
    Can you please post a full set of test results? If you do not have a reliable test kit, I would suggest the TF100. You can do a comparison here Test Kit Comparison.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Lee3 View Post
    Welcome Lee!
    Stop everything where it is. Do not add more acid right now. Sorry, but I have more questions than answers, and we need the answers to help you.
    What do you mean the chems are way off, what are you testing for, and what are you using for results?
    How big is this pool?
    Please post some numbers, particularly pH.
    Based on what you say about the finish becoming rough and loose, you could be destroying, or damaging it severely.
    Essential Links:
    Jun 2014
    Longwood florida
    3
    Quote Originally Posted by Brushpup View Post
    Welcome Lee!
    Ok so the pool is 22000 gallons and I have attached our last 2 read outs from local pool companies.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The pH of 6.8 and 0.0 of TA is wrong. Your pH is lower, and I would not trust those people advising you at all. Notice the one test doesn't even say the number. If you want to know, I strongly suggest testing this yourself, but know that the common pH test with phenol red will not go below 6.8.
    Essential Links:
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    5 Gal of MA a week is A LOT of MA. I've used 5 gals on my new sunstone quartz finish over 1 month. (new plaster will undoubtedly raise the pH of the water, also the pH of my fill water is >8.2).
    I strongly suggest you order a proper test kit like the Taylor 2006, or the one most here use the "TF100" from www.tftestkits.net. Your pH is crazy low, I guarantee that. Yes that absolutely can/will damage the plaster finish. That white dust is plaster which has dissolved in the acid bath that is your pool.
    I don't know what the actual cause of the dark stains was....but you've got bigger fish to fry at this point.
    I would call the company back out.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Lee, if you come back to read this, I didn't mean to sound brash or rude, but those numbers and what you describe is very concerning.
    Essential Links:
    Jan 2013
    Houston, TX
    1,079
    Sounds like a no drain acid wash. They are trying to burn the first layer of plaster off to hide their mistakes. I would get in touch with the manufacturers rep and have them out to look. Sounds like the plasterer owes you a redo. User OnBalance here knows more about plaster than anyone I have ever met. Also do a google search for OnBalance plaster, their website and industry studies should come up.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Even if they are, I think this has gone beyond that. This is going beyond weeks now! Even hot starts don't take that long.
    My other main point is that the test results are wrong.
    You cannot have a 6.8 pH at a 0.0 TA. It simply isn't possible. Anyone giving those results and not explaining should not be trusted.
    Essential Links:
    Jun 2014
    Longwood florida
    3
    Hey guys, firstly thanks for all your help I really appreciate it! I had the guy ( plasterer) come over yesterday and he was telling me it's all fine now and to get the chemistry back to normal, so I'm going to do that first. I'm also going to call the rep for the plaster company and get some advise from them too. Thanks again guys!!!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Great!
    Did he tell you what to do? Not to hound you, but this won't be possible to do correctly without a good test kit. You can get the best value for the dollar and the best customer service at TFtest kits. Yes I am biased, but you cannot beat the value of this kit anywhere I am aware of. Let us know if you need any help, and thanks for the feedback. Wishing you the best of luck with everything.
    Essential Links:
    Jan 2013
    Houston, TX
    1,079
    I would still follow up with the manufacturer. That procedure does not sound right. Entirely possible that it shaved a few years off the life of your finish or voided the manufacturers warranty on the materials.
