Results 1 to 15 of 15
Thread: New here and cant wait to start learning! Soon to be above ground owner!
    Jun 2014
    Brentwood, Ca (Nor-Cal)
    206
    Hello all!
    With the heat fast approaching in Northern California, My GF and I are looking at a about ground Pro-Series 16x48 (on sale for $300!) as a investment for this summer. Even if it lasts a few years, awesome LOL!
    Kind of excited as its our first purchase together, I plan on taking out some of my lawn, leveling and capping sprinklers then make a border of rock or mulch with some plants around the pool. My grandfather had a in-ground and he was def a pool man, he raised me so I must learn as he recently passed away
    Thank you for a great site and glad I was linked to here
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Re: New here and cant wait to start learning! Soon to be above ground owner!
    Welcome to TFP slammed
    Stick around, read some of hte pool school and some of the posts....
    post pics and keep us informed when you start working on it!
    Divin Dave,
    Jun 2014
    206
    Usually like a weekend job? I have a local yard I can get sand from. Builder or play/coarse sand work?
    My area currently
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Casey's Avatar
    SW PA
    10,457
    Welcome. You are going to need to read some Pool School. I'll add some reading material for you...
    ABC's of Pool Water Chemistry
    Recommended Pool Chemicals
    Chlorine CYA Chart
    Test Kit Comparison
    Jun 2014
    206
    Why thank you for the links =)
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    So short run down:
    1. Remove sod
    2. Use say a 10' 2x4 (for 16' pool) with level taped on
    3.Remove high side until even
    4. Set pavers on ground and fill with sand, recheck levelness paver to paver and from center
    5.Wet sand so it settles
    6. Lay tarp (or foam then tarp
    7. Put up pool
    #4. Do I set pavers on ground and make area surrounding paver with sand or bury in ground.
    Can I use my outside power plug on back of house on patio if GFCI? It's about 20 ft from the pool
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Plan to spend waaaaay too long getting the surface ready. Stockpile Motrin and beer before you start.
    Here's a couple really good threads you should read.
    http://www.troublefreepool.com/threa...ing-27-AG-Pool
    http://www.troublefreepool.com/threa...ling-my-ground
    If you scroll through the construction and above ground forums, look for long and or starred and or intriguing threads. See what others have done that works, and what others have done that were terrible ideas. That's the beauty of this forum: you don't have to make every mistake yourself!
    Jun 2014
    206
    Is there another "above ground " section? Yes, bud light yum! I've been reading since yesterday afternoon and gas me even more eager. Never thought I'd wanna rip up lawn so bad.... Must study first!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Water is flowing!,
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Coonspool's Avatar
    Mar 2013
    Princeton, Indiana
    85
    On my first intex, I ran a 25 foot extension cord to pump, it was hooked up to GFCI electrical box. I did use a heavy duty 12 gauge 3 prong cord. If it was the "right" or "proper" thing to do..... I don't know? But, I didn't have any problems for two years with it.
    21' x 54" AGP Heritage 12,000 gallons.
    Hayward Power-Flo Matrix SP15922S 2 Speed 1 HP
    Hayward Pro-Series S244T 24"
    My SLAM Another swamp, is it worth it? Drain or gain?
    Jun 2014
    206
    well its filled and up! Now for chemicals ekkkk! First TF-100 test wasnt bad, I was scared when I opened it and felt overwhelmed LOL!
    FC -2 (4 drops)
    CC- 0.5
    Total Chlorine- 2.5
    CH- It turned blue right after adding the R-0010 (maybe due to water softener?)
    TA- 90 (9 drops it took)
    CYA- 0 (filled the whole tube and can still see the black dot, no chem in pool!)
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    Centreville, Md
    2
    OKay....So..Bought a Intex Ultra Frame 26' x 52" pool. (15000 gallons) The filter that comes with these pools just can't keep up. Want to upgrade to a sand filter, but don't want to buy something either too small or too large. Suggestions please.....I also have a Salt water system by Intex...HELP !!!!
    Jun 2014
    206
    I'd search, do u have the Hayward skimmer ? If not do it asap
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Mar 2014
    Las Vegas
    288
    I don't think there is such a thing as too large a filter. The bigger the filter, the less backwashing or cleaning cartridges needed.
    Just my 2 cents. Go with the biggest you can afford.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Jun 2014
    206
    Well I'm 1" out of level and one pool leg was getting close to the edge of a paver after filling. I added a extra paver to the outside and will fix at the end of the season most likely. Rope isn't tight on the leg so that's positive!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
