Thread: Adding CYA....
    Feb 2012
    Winston Salem NC
    161
    Adding CYA....
    Hopefully this is a simple question...
    I always see the recommendation of hanging CYA in a sock in front of a return and letting it dissolve. I did that the first time (this is our third summer with the pool). However, when I have added it since then, I always put it in a sock and hold it in front of a return and constantly squeeze it for about 10 minutes and it all dissolves pretty quickly. It never seems to be an issue, and I always hit my target. Is that an "acceptable" way to add it? I am a little impatient, so that is why I started doing it.
    18x36 IG Vinyl. ~29k Gallons.
    Pentair CCP420 Cartridge Filter
    Pentair Inteli-flow VS Pump
    Hayward Goldline SWG
    Tigershark QC Robot
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Adding CYA....
    I see no problem with it as long as it isn't just forcing CYA dust out to settle in drifts on the floor.
    What brand dissolves that fast?
