Thread: Perilous CYA test question
    May 2014
    MILLSTONE TOWNSHIP, NJ
    87
    Am newbie...is "cya dilution test" different than the cya test in the tf-100 test kit? If so, what is it as I am just getting ready to SLAM after a pool refill and the CYA measurement is the key...thx!
    33,000 gals, DE, IG, plaster, Purex Triton FNSP 60 filter, Pentair Super Flo 2hp, Pentair MinMax Heater
    Jun 2012
    Rochester, NY
    247
    Re: About to start BBB, first steps
    Quote Originally Posted by perilous View Post
    The CYA test in the TF-100 only goes up to 100. For readings of 90-100 it is recommended to run a CYA dilution test. You can try the CYA test using a 50/50 mix of pool and tap water (instead of all pool water) and then doubling the test result to get a little better idea of how much water needs to be replaced to lower the CYA.
    Rick
    Installed June 2012 Aqua Leader 24ft Round AG Influence w/54 inch walls 13,500 gallons
    Cartridge Filter 100SF, 1.5HP
    Aqua Plus Smarte System - In for vacations, BBB all the way.
    Love my PVC Solar Cover Hangers
