Thread: Need some advice on CYA, TA, & CH
    Judodad's Avatar
    Jan 2014
    Burleson, Texas
    12
    Using my TF-100 Test Kit here's my readings
    FC = 5.5
    CC = 0.5
    CH = 350
    TA = 50
    CYA = 20
    PH = 7.8
    Sounds like I need to add stabilizer and I'd like to get my CH to 300. I've never had TA that low.
    Thanks in advance for your help.
    17k gal., IG, Pebble Sheen,150 GPM Cartridge CCP420 Pentair 420 Sq.ft Filter, 3 HP Pentair Intelliflo VS-3050 Pump, Letro Legend 4 Wheel Cleaner, 2 HP Pentair Booster Pump, Pentair Intellichlor SWG, Easy Touch Control System With Remote, Intellibrite Led Light, Waterfall, Oklahoma Flagstone Coping, Tanning Ledge w Bubblers, 2 Skimmers, 4 Returns, Built In January 2011.
    30,432
    Re: Need some advice on CYA, TA, & CH
    I agree with most of your assesment.
    1. Raise TA to 100 using baking soda
    2. Recheck pH...lower if 8.0 or above
    3. Raise CYA to 50 ppm
    Leave CH alone....it's fine and will slowly rise.
    How does your water look?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    5lbs of Baking Soda will raise the TA from 50-70. Pool math is your friend. http://www.troublefreepool.com/calc.html
    I wouldn't worry about CH. I run my CH at 500.
    I'd bump up the CYA to 75 or so about 8 lbs.
    What's your salt at?
    30,432
    EDIT - I overlooked your SWG....bobodaclown is correct....CYA 75. Sorry!
    Judodad's Avatar
    Jan 2014
    Burleson, Texas
    12
    Water is clear, salt is 3500. I was thinking the same thing after plugging it in to the pool math calculator but I wanted to make sure I wasn't overlooking something. Thanks for the advice guys!
