Results 1 to 16 of 16
Thread: Installing valve actuator
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Hi all,
    Just received the Intermatic actuator for my sheer decent valve. Spent half an hour looking at my Aqualink rs control center and I'm not sure how to hook it up. I have Intake, return and solar JVA sockets all unused, but how do I assign one of them to use for what I need? And how do I add the new option to my Aqualink touch remote?
    For the life of me I cannot find my manual for the control center either...so can't look anything up.
    Any help would be appreciated.
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    38,415
    Re: Installing valve actuator
    I am sure the manual is available for download somewhere. I can't help
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Yea looking for it right now, but hopefully there are folks on here who've installed these and can walk me through, it'll make my life so much easier))
    38,415
    These automation systems are so non intuitive a manual is still needed for my own programming.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Yea I hear that... I called Zodiac support, thinking they may walk me through, and the support guy was completely non interested in helping. Eventually, told me I need to call the tech for any wiring issues. Well, I'm not wiring anything, just need to plug it in and then program it. It's the programming part that I'm not sure about it mainly.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Folks, anyone? I can't be the first person adding a JVA to a control center... I really don't want to spend $$ on the service call for what's probably a 10 min. setup.
    I really appreciate it.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Here's the manual. I know nothing about automation...but here's the water...hehehe. aka manual.
    http://www.zodiacpoolsystems.com/~/m.../H0334000.ashx
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Thank you, I actually already found the manual, but it's very generic on JVA assignments... Hoping someone can chime in that has done this and can walk me through.
    38,415
    Or you could figure it out and help people in the future. Afraid you may be waiting a long time.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Oh believe me I'm trying, just to no avail unfortunately thus far.
    poolkid's Avatar
    Mar 2012
    Mesa, AZ
    77
    Just to be sure of the control type - you say you have the Aqualink Touch. This is the one with a color screen like this one, right?
    If so...
    1. Plug the valve actuator into any of the 3 sockets
    2. Go to Menu --> System Setup --> Assign JVAs (usually on page 2)
    3. On that page, highlight the button on the left side that corresponds to the socket used for the actuator
    4. In the list to the right, choose an unused AUX
    5. Go back to the "System Setup" page 1 and go to the "Label Aux" page
    6. Choose the Aux that you assigned the actuator to
    7. Label with either one from their lists or custom label if desired, then touch "Save" (this is critical!!!)
    8. Back your way out to the Home page (not critical)
    9. It should work fine at this point, but you might want to power down the Aqualink control board in the power center outside to get the changes to take
    10. Enjoy!
    APSP Certified Building Professional
    APSP Certified Service Professional
    NSPF Certified Pool Operator
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Yes this is exactly it and it worked perfectly! Thank you!!!
    And how hard would it have been for Zodiac support to walk me through this.... That's exactly what I asked and they kept telling me that this requires a tech to come out. Took all of 5 minutes.
    One thing I've noticed that I found strange is that both intake and return JVAs are showing as "busy" but nothing is plugged into those sockets (I was planning to use one of those, but ended up using solar JVA socket). I thought those are used for spa JVAs, but I have no spa....
    poolkid's Avatar
    Mar 2012
    Mesa, AZ
    77
    Even though you don't have a spa, the unit might have a CPU that is coded for a pool/spa combo. That would lock out the use of those for auxiliary uses. If you go to the help menu you can look into the exact model and Rev number for your CPU.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    I see.
    Here's the info:
    Model: rs8-combo
    Aqualink: rev-t
    CPU p/n: b0029221
    Does that tell you anything?
    Is that possible to replace the CPU that's for pool only without replacing the entire system? It would be nice to have these JVAs available as I have more plans in the future
    poolkid's Avatar
    Mar 2012
    Mesa, AZ
    77
    Quote Originally Posted by Azmp1 View Post
    I see.
    Here's the info:
    Model: rs8-combo
    Aqualink: rev-t
    CPU p/n: b0029221
    Sent from my iPad using Tapatalk
    Yes, you can replace just the CPU. You'll have to reprogram it from scratch - which isn't really too big a task.
    Was the install done by a contractor? If so, they can call Zodiac and they'll send a free CPU with a shipping label to return the old one.
    If it's a DYI install, I'm not sure of the policy.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    yes the system was installed as it is now as part of the pool build. I will get a hold of my builder and will ask him to do what you've suggested as I certainly don't need pool+spa CPU.
    thank you!
