Thread: High PH but low CYA
    MirellaJoe's Avatar
    Jun 2013
    Aurora, Ontario-Canada
    125
    Question High PH but low CYA
    I just tested my pool and everything else seems to be in tack but the PH being high at 9 and my CYA is 0....I know to lower PH is to add muriatic acid but i'm confused on the CYA.... ie. is it normal for it to be low when the PH is high?
    Intex Ultra Frame 16'x48" sand filter w/intex SWG.
    Pool Blaster Max Vacuum
    3rd year with Intex and no problems
    Pentair Mastertemp BTU 125/ propane
    Taylor K2006 Complete FAS-DPD
    38,539
    Re: High PH but low CYA
    They have nothing to do with each other. Have you added any stabilizer? Is it a new fill? Then it will be zero.
    How did you measure pH that high?
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    They are independent of each other, but when you add CYA it lowers PH.
    http://www.troublefreepool.com/conte...ater-chemistry
    MirellaJoe's Avatar
    Jun 2013
    125
    ok I will add CYA, thanks for the help !
