Results 1 to 8 of 8
Thread: Chlorine going bye bye in my pool
    Mar 2014
    Chesapeake, VA
    74
    Greetings to the all knowing of TFP. My pool is doing great but with one problem. As you can tell in my signature block I have an Intex 16'x48" AGP. with Intex SWG. I can't keep the chlorine levels up about 5 or 7. they keep dropping off.
    Do I need to add some sort of stabilizer to the water to keep the levels up?
    Dave Graham
    6,000 Gallon 16' x 4' Intex Round Ultra Frame
    Hayward S244-T Sand Filter, Intex SWG, Hayward SF1593 1.5hp Pump, Hayward Thru-Wall Skimmer
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    Re: Chlorine going bye bye in my pool
    Do you have a good test kit? If not you will need to get one so you can test your water.
    Have you added any kind of balancer/stabilizer to your pool? Without it the sun will take all of your chlorine. The stabilizer (CYA) with buffer the chlorine from the sun. You can also have too much CYA.
    Mar 2014
    Chesapeake, VA
    74
    I have the Taylor K-2005, in another thread I posted my levels. but I will go pull them now and post them here.
    Dave Graham
    Mar 2014
    Chesapeake, VA
    74
    Correction, Taylor K-2004B
    Results: (Keep in mind I just added 1/2 gal of 8.25% bleach)
    Water Temp - 84
    FC - > 10
    TC - > 10
    CC - > 10
    Ph - 7.8
    TA - 40
    CH - 10
    CY - 30
    Dave Graham
    Jul 2012
    Tallahassee, FL
    30,672
    Okay I see the FC, TC, and CC are all listed as >10 BUT what are their exact values/levels? If you have more that .5 CC you need to SLAM so.............
    I cannot find what tests the Taylor K2004B kit has.
    I am sorry I cannot be more helpful.
    Kim
    Mar 2014
    Chesapeake, VA
    74
    my kit only goes to 10, I will order the TF100
    Dave Graham
    Casey's Avatar
    SW PA
    10,461
    Definitely order the TF 100 DaSarge. If your stabilizer is 30ppm you will need to increase it if you're using a SWG. Once you get your TF100, we can offer you more advice but in the mean time, I'd bring the CYA level up to 70 using PoolMath.
    DaneCE's Avatar
    Jul 2011
    VA
    280
    Hi Dave. I see you're in Chesapeake. Deep Creek here. I just tested my CYA 2 days ago to find that it didn't even come close to 30 and I was at 55~60 last summer. I was surprised. I guess that's what a ton of rain and snow will do.
