Results 1 to 8 of 8
Thread: Is it ok to leave the solar cover on for days at a time
    jimmerz's Avatar
    Jun 2012
    Pittsburgh, PA
    169
    Is it ok to leave the solar cover on for days at a time if not swimming much? I am still checking my chlorine and running my filter and all looks good but I have not removed the cover in several days. My wife was nervous and said we will grow algea, I told her as long as the chemistry was ok and the filter ran enough to remove whatever we should be fine.
    24' x 54" Oceanic Round AGP, 1090 Hayward Skimmer, EC-40 Filter system, Automatic Chlorinator. Pool will be in Full sun for most of the day (9am-6pm).
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Re: Is it ok to leave the solar cover on for days at a time
    It is fine to leave it on and you wont grow algae as long as you maintain appropriate FC level (algae needs sunlight so in theory the cover might actually help prevent algae). I keep mine on for extended periods and the only issue I ever have is the water getting too warm. I have heard that you can get measurable combined chlorine since the sunlight isn't breaking them down, but I have never experienced this.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    jimmerz's Avatar
    Jun 2012
    Pittsburgh, PA
    169
    Thanks. My FC has been holding steady for 3 days now.
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    You may find it a bit cloudy as the skimmer does have a hard time working well with the cover on. If you're having a party and require it to be clean, I'd suggest pulling the cover off every now and then for the skimmer to work well.
    jimmerz's Avatar
    Jun 2012
    Pittsburgh, PA
    169
    Thanks Leebo.
    ranger_ric's Avatar
    May 2014
    Midland TX
    183
    I am thinking about putting my solar cover on over about 80% of my pool and leaving the skimmer exposed so water can circulate well. Has anyone ever tried this?
    17500 Gal Above Ground, 1.5HP Dynamo Pump, 250# Pentair Sand filter with ZeoLite. Diver Dave Cleaner. TFP test kit w/SpeedStir, 7 Grandaughters and 1 Grandson swimming every week WooooHooo!!
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I think Leebo's comment may be misleading. The cover doesn't put any extra strain on the pump and the water is still circulating under the cover just fine.
    The skimmer takes in debris floating on the surface of the water, so with the cover on the skimmer has a "hard time working well" in the sense that all the debris that would have fallen in the pool is now sitting on the cover.
    Remember that, depending on how you remove the cover, much of that debris will end up falling in the pool. I use a cover roller, so when I remove the cover all that stuff falls in the pool. There is also some debris that gets in around the edges. If the cover has been on for more than a day or two I will run the cleaner once the cover is off, which also has the effect of allowing the skimmer to clean up the surface.
    Casey's Avatar
    SW PA
    10,423
    I have found that my pool gets algae with the cover on for more than 2 days, even while being dosed with chlorine. The floor gets slick and when it gets brushed, it will plume a green/yellow dust. Individual mileage may vary... my pool doesn't like to be covered 24/7.
