Thread: The Boss says I can buy a robotic cleaner
    Aug 2013
    Ottawa,Ontario
    35
    So the Boss says I can buy a cleaner so do I go with the premier @ pool express or Z5 @ epic ??????????? What to do
    22k,IG Vinyl,Hayward Dual Speed Pump,Hayward Cartridge filter C3030,SWG 9 Cell Pro-Logic, 4 Relay System,Dolphin Supreme M4
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: The Boss says I can buy a robotic cleaner
    I'll give a review of my z5 this weekend. If it anything like brushpups m5 it will have a full two thumbs up.
    What do your main drains look like? The reason I ask is the ONLY negative I've read anywhere about the z5 was a guy with a vinyl pool. Who stated it got stuck on his main drain. BP has the same drains as I do and his m5 has zero problems. It will be included in my review.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,003
    The boss will then demand a Roomba!
    Aug 2013
    Ottawa,Ontario
    35
    I have 2 Aqua Genies so no bottom drains
