Results 1 to 18 of 18
Thread: Looking to buy Pro Series 14x42, review and setup tips?
    Jun 2014
    Brentwood, Ca (Nor-Cal)
    206
    Hey all, my gf and I are looking at getting a above ground pool for the house this summer. Gets high 90s to 100+ around here. Anyone have experience with these styles?
    Heard good things so far. Going to put it on the lawn but that's easy to reseed, I heard you can leave up all year if you want, true? Any links or tips appreciated.
    Did you put sand down over the lawn or remove lawn? Best way to level with 2x4 and level taped on. I will place of course where no sprinkler heads are but what about sprinkler spray?
    I'm thinking of doing it once and right so I can leave up. sand to level with a 3 ft bark or rock border with plants.
    Opinions on ProSeries? Is it made by Intex? Can't find much online about them.
    http://mobile.walmart.com/ip/ProSeri...e-Kit/33154209
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    38,546
    Re: Looking to buy Pro Series 14x42, review and setup tips?
    Welcome to TFP!!!
    You want to remove the grass to avoid rotting under the pool. The key is to get the area level by lowering the high side, NEVER raising the low side without special considerations.
    There are lots of build threads you can search for showing the process of leveling the ground.
    Good luck and post pictures
    Jun 2014
    206
    Thank you, sounds like a weekend job, I like it. Btw just found a 16x48 for $20 more
    http://m.target.com/p/16-x48-ultra-f...FYGTfgodiq4Arw
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Intex ultra but prob go with this ProSeries 16x48 for $299 as people say the filter skimmer is better
    http://www.walmart.com/ip/Summer-Esc...ingMethod=p13n
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Will sprinklers rust pool frame? The faulty liner reviews scare me with the intex
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Area I plan to convert to a pool space, most likely 20x20. Can I just cap my unused sprinklers on that side?
    Other side of the far overhang post
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    There are heaps of people on here with Intex pools, and I haven't read anything to severe about the liners failing.... Just trying to put your mind at ease....
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Casey's Avatar
    SW PA
    10,461
    Good luck with your build. Make sure the ground is level the first time so you're not wasting water out there in CA and time!
    Jun 2014
    206
    Why thank you, so pavers for the legs go even with the sand correct? Going to buy the 16x48 this weekend while on sale. My biggest concern is leveling. 10 or 8' 2x4" mounted with level sounds like my best friend
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    I have the 16x48 pro... and while I do like the skimmer... but now that I know now about the inadequate pump, and the likelyhood of upgrading to a sand filters which I did after having mine only two weeks. I might have just bought the intex and a hayward skimmer for the intex and cut the liner as others have done here.
    I have had a heck of a time finding a way to adapt the pro series over to the intex sand filter. Just food for thought.
    Installed May 2014 - 16' x 48" Summer Escapes Pro Series Pool AG Vinyl (6,000 gal) - Intex 2650 Sand Filter - Christmas, FL
    Jun 2014
    206
    That's a easier conversion than molding the ProSeries? I prob would enjoy it this summer then upgrade next winter or summer.
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Waldog's Avatar
    May 2014
    Christmas, FL
    189
    The connections for the skimmer and the return are 1.5" on the pro series and not quite 1.5" on the intex. I think they are 1.25" so it's not a direct connection. I had to get adapters and get creative. There is probably a better way, probably using PVC and adapting the intex screw on hoses to a smaller pipe or hose then using the existing connection but I did not have a hose with me when I went to the store, so I could not match up anything.
    With the intex pool everything should fit up, you would just have to install the hayward skimmer, and I'm betting it has a more standard connection as well.
    May 2014
    Corona, CA
    21
    Slammed01
    I have the size down from that the 14'x42" and have made the mods to run the upgraded intex pump and sand filter. My word of advice would be not to waste your time with the intex B adapters. I had to upgrade because the stock system died on me in two weeks. There is a great Youtube video on how to do this mod. Following and you will be set. The mod takes a steady hand and some dremal skills for sure!
    http://www.youtube.com/watch?v=alUEtP2Nq9E
    Intex 14'x42"
    Intex 14" 2800gal sand filter pump
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    http://www.troublefreepool.com/threa...ex-18-x-9-x-52
    I would go with a rectangle pool, they take up less room and you can get a decent lap in them.... I've cut my liner to accommodate the larger Intex strainers and its the best thing I've done,,, I'm also cutting the liner to install the Hayward through the wall skimmer....
    Jun 2014
    206
    Thanks all, found a Intex 16x48 finally after calling a few stores and put their last one on hold! $300 is a deal and sale ends tomorrow... as everyone else wants $400+ and they are even sold out.
    I can return. I've the sod with a flat nosed shovel correct? I don't NEED a sod cutter right?
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    May 2014
    san tan, az
    61
    You dont need a sod cutter but will probably want to rent one to speed up the process. I leveled my ground using a 4' level by itself first, then attached to 2x6x10 stud to level the last 6 feet.
    18'x48" Intex Ultra-Frame (Grey), Intex 2150gph Sand Filter (#28647EG), Intex Krystal Clear SWCG (#54601EG), Hayward SP1091LX Dyna-Skim, Intex LED Light.
    Jun 2014
    206
    Picked up the intex and a family friend is going to start the process this week. He put up his 32x16 14 years ago. Picked up the intex today and looking to do the skimmer mod then new pimp next year.
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
    Jun 2014
    206
    Is a 17' circle ok to level or should I go farther? I will be doing landscaping after pool is up!
    16x48 Intex Ultra
    Hayward Skimmer
    TF-100 test kit
