Thread: To Paint or Not-Paint Bottom Rails and Plates
    PPrince's Avatar
    Jul 2013
    North Coast of Ohio
    55
    I purchased a used 18' x 48" steel wall pool. When taking it down I discovered that many of the bottom plates and bottom rails were pretty rusted. I looked around and found replacement parts and ordered all new. They are galvanized metal (which I assume the original ones were too,) and I am wondering about painting them with a rust inhibitor type of paint before assembling the pool.
    Any suggestions or thoughts? Basically I'm thinking it will slow down the rusting, especially if I go with a salt water system.
    Paul
    8000 gal 18' x 48" AG steel wall pool, 1 HP Hayward Perflex DE filter, SWG, Jandy Lite 2 Heater - 175K BTU
    Casey's Avatar
    SW PA
    10,448
    Re: To Paint or Not-Paint Bottom Rails and Plates
    It couldn't hurt. Good luck and post pics!
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    I painted mine on my 20 yr old pool, also the uprights and top rails. May have been overkill but easy to do and looks good
    12 x 28 Doughboy Dinosaur (j/k: Breckenridge) partial bury, continuous depth 9,000gal. Doughboy Power Pak I digital 1hp pump, Hayward Pro-Series 300lb sand filter. Foam panel base, Gladon wall foam, Gladon cove.
    PPrince's Avatar
    Jul 2013
    North Coast of Ohio
    55
    Thanks. I will add that to my "To Do" list then!!
    Paul
