Results 1 to 8 of 8
Thread: Cant get control of metal staining
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Hey all,
    Ive been struggling with metal staining for weeks.
    My numbers are where they should be. Fc 2-3. Ph 7.2. TA is low... About 40. Ill bring that up.
    Ive intentionally kept my ph in the low 7s constantly. I havent shocked the pool.
    I add about half a bottle of sequestering agent each week.
    Yet I still get stains coming back on a weekly basis.
    Not the overall pool discoloring ive gotten before i got control of it.
    But many very large spots across the pool that require a bottle of abscorbic acid to remove.
    This is becoming expensive and making it harder to control my levels.
    Its been going on for over 3 weeks. At this point Should I just start replacing water 1/4 at a time or something? Ive really had enough of this. Its never happened to me before in 10 years.
    Thanks a lot
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Re: Cant get control of metal staining
    Replacing water sounds like a good idea.
    The more metals there are in the water, the more sequestrant you need to use to prevent stains from appearing. From your description it sounds like the metal level in the water is quite high, and so you haven't been using enough sequestrant. Sequestrant is also expensive, so if there is any way to replace water with metal free water that is probably worth it.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Quote Originally Posted by JasonLion View Post
    Thanks a million for the help.
    I am going to take your advice. I wish I knew where the metal came from. I had no issues last year. Closed the pool up. And upon opening this year it was awful. I closed insanely late last year and a storm dumped about 10 million leaves in the pool. Is it possible for them to contain so much metals?
    Its amazing what one can of AA does. The pool immediately shines like new. But i know its just an illusion. Its the matrix of pools
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    I put 4 lbs AA powder in mine followed by a seqestrant. Stains lifted immed. And it was beautiful! Now waiting for cloudy water to clear from the seqestrant....have you read TFP thread on AA treatment?
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Quote Originally Posted by smforte View Post
    I dont need help with AA treatments. As per my post, getting the staining out is easy. Keeping the staining out is another matter. Again ph kept low 7s. Chlorine well balanced. Sequestering agent put in every week. Yet staining continues to return. Which tfp thread helps with that?
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    If the stains keep coming back have you considering draining to get rid of metals?
    Montgomery, AL
    ps0303's Avatar
    Jul 2011
    FL
    3,689
    When you get metals in the pool you have to keep adding seqestrants. As you mentioned, you could empty the pool completely and do a refill and hope that your metal issue is gone. However, I would get your water tested before you add any into the empty pool to make sure you aren't re-adding high levels of metal back in.
    Metals don't go away, you can only hold them at bay with seqestrants.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    30,411
    I don't know exactly which thread it is but I would figure out the source of the iron.
    If you haven't had issues before, then why has iron suddenly appeared in your fill water? Is it the same fill water as always? Is it from a well?
    Iron doesn't come from leaves, rain water or any other source....it's your fill water (or someone is purposely introducing it which is implausible)
