Thread: Summer is Here...Check your Stenner Pump Tubes
    NoFear95's Avatar
    Mar 2013
    Phoenix, Az.
    138
    Had my Stenner pump for almost one year to the day. Heat just started in Arizona here and I went to do my weekly check on my chlorine level, turned out it was 0. Checked on my pump, and the tube dried out and wasn't pumpping.
    So change you tubes annually.....public service announcement!
    Chlorine levels are back to normal and my pool looks amazing thanks to the BBB method!!!
    IG, 18K gallons, 100' Perimeter, 565 SF surface area, 980sf interior area, Max Length -36', Max Width - 16', Pentair 520 Clean and Clear Cartridge Filter, Stenner Chemical Injection System (Chlorine, Acid Coming Soon) , Pebble Tech - Blue Granite, Pentair variable speed filter pump, Zodiac MX8 Cleaner, Multi-Colored LED Lighting, Travertine coping & Decking, Boulder Water Fall....
    22,553
    Re: Summer is Here...Check your Stenner Pump Tubes
    That's a good reminder. I change mine yearly. It's a good idea to put them on a list to at least check periodically.
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Thanks for the tip, I will order some extra ones on my next purchase...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
