Thread: Pool Opening Issues
    Jun 2014
    Dayton, Nj
    2
    Pool Opening Issues
    For last 3 years I have had Pool Shop open our pool during spring season. This year in an attempt to save money tried doing this myself and now I am seriously questioning my judgement. It might very well be possible that these issues might still have surfaced if professionals had open our pool. Hoping that I can learn by mistakes and save some money in future. Here are a couple of things with which I really need help -
    1. Pool Heater: We have a Hayward 250BTU natural gas heater. I opened up the main gas valve and tried firing it up, but after few attempts it showed me an IF error. Am I missing any steps? What should I do to get the heater working again?
    2. Step Jets: I removed the winter plugs and installed the step jets, but the water flow doesn't seem to be same as prior years. We also don't see any air bubbles even when we open up the screw that's on the top left corner of the step jet. Also, I have threaded one of the O rings the other way round. Basically the side with the hooks is inside. What's the best way to remove it and put it back properly?
    Really appreciate any help you can provide on this.
    Pool Size/Type: 16x36 / Inground Vinyl
    Filter: Sand (Hayward)
    Pump: 1.5 HP (Hayward 2 speed)
    Pool Built Year: 2010
    Other Details: Salt Water Chlorinator, Hayward Pool Heater (H250FDP)
    Jan 2013
    Houston, TX
    1,079
    Re: Pool Opening Issues
    Welcome to TFP!
    I can't be much help on opening as mine runs all year - but I can give you a bump to get more eyes on...
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
