Results 1 to 11 of 11
Thread: CYA testing
    26venus's Avatar
    Jul 2013
    Shenandoah Valley, VA
    48
    CYA testing
    I just received my bottle of CYA 50 standard yesterday and I'm wondering how exact is the standard? I know that the CYA test results are probably the most subjective of all results but is the standard exactly 50. The reason I ask is I performed several tests with the 50 std. and consistently read 40.
    The tests were performed indoors in a very well lit room under fluorescent bulbs. This is usually the where all my tests are performed.
    16 x 36 IG Vinyl, 20,000 gal, chlorine, built 2001
    Hayward 3/4 HP Super Pump
    Hayward Pro Series sand filter S210T
    All in with TFP , testing with tf-100
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    Re: CYA testing
    Quote Originally Posted by 26venus View Post
    My guess is the lighting is what is causing the difference .... the directions call for outside in bright sunlight.
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    26venus's Avatar
    Jul 2013
    48
    Re: CYA testing
    I considered that but prior to testing the standard I've always achieved the same results outdoors as I have under the lights. I will retest the std. today both indoors and out and post the results.. Thanks to mother nature outdoors was not an option yesterday.
    38,248
    Re: CYA testing
    You certainly do not want light shining down into the tube or you will get a lower reading.
    You need to play with the standard to figure out what you need to do get 50ppm ... someone reported then needed to hold the tube up higher than waist level.
    26venus's Avatar
    Jul 2013
    48
    Re: CYA testing
    So what you're saying, as an answer to the direct question, is that I can put faith in the standard as truly being 50. If that's so I can work around whatever it takes to make it read correctly or even compensate if I can't.
    38,248
    Re: CYA testing
    Yes it should be truly 50.
    Re: CYA testing
    The standard will be quite close to 50, presumably within +-1, so between 49 and 51, far more precise than you can measure with the test.
    26venus's Avatar
    Jul 2013
    48
    Re: CYA testing
    Thanks guys. I'll still post my findings once I have them.
    Fort Worth, TX
    83
    Re: CYA testing
    I found out to not be locked in to the waist level test.
    Put the standard solution up to the 50 mark in your test vial. Move it up and down under your eyes until the dot just disappears. Notice where the vial is in relation to your torso.
    That's where you want to hold it when you test your pool water.
    The light doesn't really make any difference as long as you test your pool water in the same lighting.
    CYA is an accurate test as long as you follow these guidelines.
    10,000 gal / Plaster / Cartridge Filter / 1 1/2 HP pump motor/ TF-100 test kit.
    26venus's Avatar
    Jul 2013
    48
    Re: CYA testing
    Quote Originally Posted by ship of fools View Post
    Kudos to Ship of Fools! I tried three different areas. Inside, I again got readings of 40. Outside in the shade of my house it read a hair above 40. In direct sunlight, sure enough it read 50. This was repeatable every time. I'm amazed at the difference. Thanks everyone!
    26venus's Avatar
    Jul 2013
    48
    Re: CYA testing
    Quote Originally Posted by BillB View Post
    I'm going to play around with this idea. I do all of my testing in my garage which is very well lit. I'd like to keep it that way for a few reasons but mainly because a bright sunny day is never guaranteed. Thanks!
