Thread: Replacing a lateral assembly on a Hayward 244s Sand Filter
    I am looking for some help. I am trying to replace the lateral assembly on an old Hayward 244s side mount sand filter, it is not the umbrella style. I can not get the assembly off the lower elbow. Is there a trick to removing this or do I need to remove the whole lower elbow and lateral assembly. Any help or advice would be appreciated.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Replacing a lateral assembly on a Hayward 244s Sand Filter
    I've never seen one, but it looks like you have to unscrew that elbow piece from the tank itself.
    https://www.hayward-pool.com/pdf/man...210S-S244S.pdf
