Results 1 to 9 of 9
Thread: Will I know the right kind of DE to get at Lowe's?
    May 2014
    Burlington, NC
    45
    Is there pool DE for filters at Lowe's or Home Depot? What kind of cost should I expect and in what quantities? I won't need much to add to my sand filter for SLAMing, right? Will I use it regularly? Backwash before or after adding DE while SLAMing?
    18,000 gallon IG vinyl
    Hayward S220T sand filter, replaced sand 2013
    Sta-Rite pump, 1HP?
    New liner, 5/12; pool built in 1981;
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Will I know the right kind of DE to get at Lowe's?
    I haven't seen any at Home Depot in my area. But ours doesn't even sell pool chemicals. I got mine online. About $1 a pound (25 lbs). 25 lbs should last a long time and you won't need to use it much unless a SLAM is in order.
    Make sure it says it's for pools, not food grade or pesticide use.
    http://www.amazon.com/Diatomaceous-E...pool+filter+DE
    Isolated Spa - 345 Gallons
    May 2014
    Burlington, NC
    45
    Okay good. Thanks!
    Sta-Rite pump, 1HP?
    jccams's Avatar
    Dexter, MI
    95
    I have seen DE at walmart
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Our local Lowes sells it with the other pool supplies, as I recall it is around $20 for 25 pounds, maybe a bit less
    Jan 2012
    'burbs of Augusta, Georgia
    7,334
    I ordered it online at ACE hardware, $14 for 10# and they delivered it to the local store free of charge.
    http://www.acehardware.com/product/i...ductId=3908901
    May 2014
    Turlock, CA
    55
    Quote Originally Posted by mamalou23 View Post
    I got mine at Orchard, but I'm sure other home and hardware stores have it too. It was pretty cheap.
    You add it 1/4 cup at a time, checking filter pressure until you see a 1 psi rise. Then you just let it do its work to help the sand filter do a better job.
    Whenever you backflush the filter it will all get washed away, so you will need to add more. I figure one box will last the rest of my life.
    21K gallon, plaster, 1hp Hayward MaxFlo pump, Hayward 244s sand filter, 3/4 hp Halcyon PB4-60Q booster pump, Polaris 280 cleaner.
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by Isaac-1 View Post
    Same at Fleet Farm here.
    Orlando, FL
    690
    I got cellulose at Home Depot. It's a DE replacement.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
