Thread: FAS/DPD question
    astronaut888's Avatar
    Jun 2013
    southeast
    118
    FAS/DPD question
    I have been maintaining my FC between 4 and 7
    (20K gallons, CYA 50)
    I add bleach at night after testing and shoot to raise to somewhere between 6 and 7 and have been steady seeing that FC has maintained nicely, not dropping below 4 even on sunny days.
    My question is, are most here using the FAS/DPD test to test their chlorine when they test.
    The other test (called the OTO, right?) simply tests a range of chlorine levels and I wouldn't be very confident trusting it to really tell me a FC level - so, I use the FAS/DPD every time - pretty much daily!
    Is this a total waste or is this the way most do it around here?
    thanks
    20K gal, IG vinyl, 1 1/2 HP Hayward Super Pump , 100lb sand, installed 2000 - new liner/filter/pump March 2014
    TF-100 test kit
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Re: FAS/DPD question
    I use the FAS-DPD exclusively for now. I tell myself that I may try the OTO once I'm confident I have a grasp on it all. But I hate the pH color match test...as I can't see slight changes in colors...so I probably won't use the OTO, and may buy a different pH test.
    IIRC the OTO test is worthless over 5ppm. (I could be wrong, as like I said I don't use it)
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    It is about 50/50. I only use FAS-DPD weekly and when there are problems, and use OTO daily. Others prefer to use FAS-DPD daily.
    OTO tells me if there is a problem or not very quickly. I have no need to know the specific FC level daily, as that is very predictable if you pay attention to the weekly numbers.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Daily I only test with the OTO since my FC range is 3-6. Typically in the evening it's 3 and since I'm fairly confident in my pool volume after getting used to it, I add enough to get me to 6 and don't bother testing after 30 minutes. I have and it's usually a little more "orangey" than the 5 so I'd say it's good. Weekly I do the FAS-DPD before and after and see if my additions are making sense and my bleach isn't under %/degraded.
    Isolated Spa - 345 Gallons
