Thread: How often should I test CYA during SLAM?
    May 2014
    Burlington, NC
    45
    How often should I test the CYA during the SLAM process?
    18,000 gallon IG vinyl
    Hayward S220T sand filter, replaced sand 2013
    Sta-Rite pump, 1HP?
    New liner, 5/12; pool built in 1981;
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: How often should I test CYA during SLAM?
    None. Should be tested before to determine SLAM FC target. If you add any to increase CYA before SLAM, assume what you added is in there and base SLAM level on that.
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    If you've lost enough water during backwashing that you replaced a noticeable percentage of water, it would be a good idea. Say... 6" or more.
    scriptorum's Avatar
    Apr 2014
    Mt. Pleasant, SC
    126
    If the water was murky when you did the initial CYA test, it's worth trying again once the water is a bit clearer.
    15K gal IG plaster pool Hayward Pro-Series Sand Filter S244T Hayward SuperPump 1HP Age: Old but "recently renovated" Mineral Springs MS10 SWCG (AquaRite ancestor) Taylor K-2006 Test kit + 1766 Salt Test Leaf eater My green to clean story: Proud owner of a glorious swamp! (LOTS of photos)
