New to the site and thought I could get some help with my pool pump, Yesterday I replace a bearing in the pump after putting it all together the pump would not pump the water throught the system, pump was running but no flow. After a sleepless night, I am wondering if I might have wired the pump incorrectly when putting it back together, question if I had put the neutral (white) wire on the incorrect place would the pump run backwards causing this problem? and if so does anyone have a diagram on the wiring for this model of pump?
thanks
