Results 1 to 10 of 10
Thread: Should my CYA level have gone up overnight?
    May 2014
    Burlington, NC
    45
    I got my test kit yesterday and the CYA tested at 30 ppm. I am SLAMing the pool. The overnight FC loss test shows a loss of 1.5 ppm FC. I tested the CYA again to make sure what SHOCK FC level to use and it tested at 45-50 ppm. Is it user-error on my part or does CYA go up with SLAMing? Just wondering and going to use the new reading to SLAM the pool today I guess. Any thoughts?
    18,000 gallon IG vinyl
    Hayward S220T sand filter, replaced sand 2013
    Sta-Rite pump, 1HP?
    New liner, 5/12; pool built in 1981;
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Should my CYA level have gone up overnight?
    Have you added CYA recently? It can take a week for the addition to fully register on the CYA test.
    Support the site
    May 2014
    Burlington, NC
    45
    No, have not added any CYA. I thought I understood that value should stay the same. What am I missing?
    Sta-Rite pump, 1HP?
    38,251
    How did you do the test? Lighting is very important.
    May 2014
    Burlington, NC
    45
    I did the test before sun was on the pool. I think it's because I added water to the pool yesterday evening. That would do wouldn't it?
    Sta-Rite pump, 1HP?
    38,251
    Adding water would lower the CYA. You need to do test outside in bright indirect light with tube near your waist. Try to test at the same time of day.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Are you using liquid chlorine / bleach for the SLAM as we suggest, or are you perhaps using a stabilized powdered chlorine product that will also drive up your CYA?
    May 2014
    Burlington, NC
    45
    Used the Austin's liquid chlorine shock from BJ's. I guess it is user error on running the test. I'll have to try again.
    Sta-Rite pump, 1HP?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If you are unsure of your readings you can pour the sample back and forth from the view tube until you are confident, it is good after mixing for several minutes.
    Ike
    May 2014
    Burlington, NC
    45
    Good to know. I will do that next time I test.
    Sta-Rite pump, 1HP?
