Thread: Bonding Pool?
    Jun 2012
    Los Banos, Ca
    7
    Bonding Pool?
    I dont know if I should bond my pool. Well I dont even know how to bond the pool. I recently purchased the Sand Master 71225 (http://www.amazon.com/Master-71225-G...cmu_pg__header) to replace the cartridge filter, but the directions state to ground and bond. I have a summer escapes pool 14x42 (http://www.toysrus.com/buy/pools/14-...2-d-1-11195811) Except without the canopy. I guess what I'm trying to ask is if I should bond or not. Here are some pictures with the set up and close ups of the filter. http://s647.photobucket.com/user/domo5360/library/pool
    Intex Metal Frame Pool 12x30
    Intex 2800 GPH Sand Filter
    Taylor k-2006
    Los Banos, Ca
    laceygirl's Avatar
    Dec 2013
    Canberra Australia
    1,273
    Re: Bonding Pool?
    I do believe your pool is classified as a temporary or portable pool, and therefore do not require bonding...
    Intex Rectangle 18 x 9 x 52', 4544 gallon (18000 litres), 0.75 hp pool pump, 100 sqft Zodiac Titan Cartridge Filter - 40mm, Stenner Peristaltic Pump chlorine injection system, Intex Over The Wall Skimmer, Intex Fittings with 40mm plumbing Lil Patch Of Heaven. Build/Construction http://www.troublefreepool.com/threa...lice-of-heaven
    Jun 2012
    Los Banos, Ca
    7
    Re: Bonding Pool?
    I was about to add that in. So we should be safe without having to bond? Should I make a "tent" like structure over the filter to avoid any splashing water from hitting it? Sorry, if I sound a bit paranoid, but it did freak me out a bit when I read about it.
    Taylor k-2006
    Los Banos, Ca
    Jun 2012
    western NY
    1,562
    Re: Bonding Pool?
    The NEC does not recognize temporary pools as needing to be bonded. This does not mean that the issues associated with needing to bond pools won't be present in a temp pool. I suspect that when they looked at the temp pool issue they decided that it would be impractical to properly bond something that could potentially be moved several times. If you feel that you should bond it, there are methods out there that would work fine with a temp pool.
    The pump, heater and all other electrical devices still need to be properly grounded and on a GFCI protected circuit
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
