Results 1 to 15 of 15
Thread: Brand New Jandy Lxi not firing
    Aug 2013
    Maryland
    93
    So,
    I finally got my pool running today. 400k Jandy Lxi Heater has been here about 6 months.
    Does not seem to be working. Starts up, but after a few minutes says Ignition Fault. I can see the ignitor lighting through the sightglass, but no flames.
    Any ideas?
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    Re: Brand New Jandy Lxi not firing
    Is this newly installed unit? If this is brand new, call and get a warranty service tech out.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Aug 2013
    Maryland
    93
    Yes new, going to contact them. Was just looking for ideas to try in the mean time.
    Aug 2013
    Maryland
    93
    So Jandy is sending a tech, but not for a few weeks. Was hoping to be able to use this sooner.
    Gas company found adequate supply pressure up to the gas valve. But the other side of the gas valve in the heater always reads 0" WC, even when the heater is trying to light. Valve has 24VAC to it and the knob on it is turned to ON.
    Can you adjust the valve outlet pressure? Like maybe it's forced closed somehow?
    Jun 2012
    western NY
    1,559
    Quote Originally Posted by andyoi630 View Post
    NO. Please do not attempt any adjustments on a gas valve. These are all factory set and are not field serviceable. Sounds like there is no signal voltage to the valve. Best to wait on the tech for this one.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Aug 2013
    Maryland
    93
    Quote Originally Posted by danpik View Post
    Interesting. After posting this I found in the Jandy LXI Manual where it says to adjust the gas valve if the outlet pressure is wrong, so now I'm confused.
    There is voltage to the valve, 24 VAC as measured.
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    What they are saying is for experienced people to do. In your case, you have an issue that won't be just an adjustment to the gas valve. These units are usually quality control tested in the factory to make sure all is working.
    When the unit is working correctly and a call for heat is signaled, you can usually hear and feel the gas valve click. If you aren't hearing or feeling a click, then you have another issue. Possibly the control module. But do NOT mess with the gas valve pressure.
    Paul
    Aug 2013
    Maryland
    93
    I can hear the valve click for sure, and can even smell a little bit of gas around the unit when this happens, but no ignition.
    Azmp1's Avatar
    Jul 2012
    Maryland
    283
    Could be the igniter. I had a same issue with my home water heater, you could see the igniter get red hot through the peep glass, but still wouldn't light, turned out to be bad igniter. Does it have any residue on it? That can cause issues.
    19200gl rectangular gunite/diamondbrite perl pool || Coverpools auto cover || Jandy variable speed 2hp e-pump & Polaris PB4-60 booster pump || Polaris 3900 sport cleaner || Jandy CV filter || Jandy AqualinkRS8 w/Aqualink touch || Jandy iAqualink2.0 || Jandy Watercolors LED || Jandy AquaPure 1400 SWCG || Hayward auto chlorinator (backup) || Raypak 117k BTU heat pump
    Aug 2013
    Maryland
    93
    I can try and check that if the ignitor is removable. It does glow hot, but no dice otherwise.
    If the ignitor glows and you can hear the gas valve open and smell the gas, then try blowing into the burner assembly. Sometimes the gas does not flow over to the ignitor. If you get full flame after that then you may need to clean the jets and manifold with a vacuum cleaner and possibly re-position the ignitor.
    ps0303's Avatar
    Jul 2011
    FL
    3,681
    Quote Originally Posted by Bugman1400 View Post
    Not xso sure getting your face into that area to blow into it and having it ignite is such a great idea. Especially if you value your health. If you did this and it was propane, you could see it light for the last time as the ball of flames could take your eyes out. Seriously.
    Do NOT attempt this.
    Paul
    Aug 2013
    Maryland
    93
    Quote Originally Posted by ps0303 View Post
    Didn't he mean with it off and the gas off
    I've never had a problem yet. This is a common method to diagnose commercial gas dryers too. I am not indicating to stick your face into the burner but, a couple of feet away should be enough. If you are applying positive pressure then the gas would flow away from you and anything that lights will also flow away from you. The instant you hear the swoosh of combustion then it makes sense to pull away. Its up to you. There are many times I would get a glowing ignitor, a click of the gas valve, and no combustion followed by blowing towards the burners and then get combustion. Afterwards, the flame and heat would burn off whatever was causing the problem and the unit would work again. This is typical during the first firing of the season.
    Aug 2013
    Maryland
    93
    So you mean take the whole panel off to the burner and blow in?
