Thread: Solar Leaks + "Fix A Leak"?
    I just bought some "Fix A Leak" for my pool.
    I also have a solar leak that I've been putting off (not the same leak, the solar is minor).
    Then I put 2&2 together.
    So... anyone know if running fix a leak through solar would be dangerous? I have Fafco panels, the tubes are .25in diameter.
    Aaron
    18K Gals, Intelliflo VSD, Pentair Catridge, SWG, Solar & Gas Heat, Pebble Tec, Jandy AquaLinks, Pool Pal for Android.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Solar Leaks + "Fix A Leak"?
    I don't know, but I think fix a leak hardens when exposed to air, so I would certainly make sure that it was set up to circulate continuously and flush things out very well when done if you try it.
    Ike
