Thread: new pool burning eyes
    My new 20,000 gallon inground pool is 4 weeks old and the kids eyes seem to burn when swimming. my water levels are as follows:
    FC= 2
    CC= 0
    pH= 7.5
    T/A= 100
    CYA= 40
    Any advice? Or should my kids just wear goggles?
    Southern California/sun all day
    26k gal/in-ground plaster/jacuzzi spillway
    dual speed 1.5/2.5 Hayward
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    Wife in bikini and Margarita maker
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: new pool burning eyes
    New water is very low in salinity, which can make the water irritating to the eyes. Adding some salt will probably make it easier on their eyes. I think most people are happy around 900-1000ppm.
    Also, with a CYA of 40 you should never let FC go below 3. The normal FC range is 3-7. Low FC can result in small amounts of CC, which can irritate. It also makes it much simpler for algae to get started.
    thanks
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    oh, one more question. I have been pretty dilligent about testing my water, usually twice per day. At what point can i expect the pool PH to stabilize so I can go a few days without checking and know that PH is fine. or, will this ever happen?
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    If you have new plaster, you can expect the PH to rise rapidly for three or four weeks, and then more slowly for up to a year.
    In general, it often takes a couple of weeks to get used to how your pool behaves so that you can anticipate what it will need and not need to test quite as frequently.
