Results 1 to 20 of 20
Thread: Baquacil to Chlorine Conversion Commencing Soon...
    Jun 2014
    Eastern Tennessee
    10
    Hello everyone!
    I've been reading a lot about the Baquacil to chlorine conversion on this forum. I can't wait to have a much less troublesome pool after it's all said and done.
    I ordered the TF-100 XL test kit on Tuesday. Looks like it will be here tomorrow! It looks like I'll be starting the process Friday afternoon after work. I bought sixty 121 oz 8.25% bleach bottles from Costco a couple days ago. I kind of have a feeling that may not be enough, but we'll see. I'll be trying my best to test every hour and top up to 15 ppm over the weekend.
    Does the TF-100 XL test kit come with enough reagent for all of the testing I'll be doing and then some after the conversion? I saw in the description it was commonly used with Baquacil conversions.
    Also, when should I stop adding chlorine every hour or so and focus on when the sun is not shining on the pool such as the evenings? I've read some people start this when the FC loss is only a few ppm with each test.
    I have a 30 foot diameter round, 4 foot deep above ground pool with a vinyl liner. So roughly 21,000 gallons of water. Right now there is a slight oxidizer residual and a sanitizer level of about 30 ppm according to the test strips but you know how reliable those are.
    Here are some pictures of all the bleach and the pool right now. I'll be sure to post plenty of pictures of the pool during the conversion as this thread is worthless without them.
    This picture below is a better representation of the pool's cloudiness.
    Thanks in advance!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Baquacil to Chlorine Conversion Commencing Soon...
    Holy Cow! Are you ready or what Welcome to TFP
    Please remember to post pics for us
    You're done SLAMing when:
    Jun 2014
    Eastern Tennessee
    10
    My test kit came in today. Tested the pH and TA. pH was 7.8 and TA was 110. I ran to Lowes and picked up a gallon of muriatic acid and added about half a gallon to get the ph down to 7.2 using the pool calculator. I'll check the ph again tomorrow before I start adding bleach. Looking forward to it!
    Casey's Avatar
    SW PA
    10,427
    You can slow down on the chlorine addition when your FC stops dropping so rapidly. If it's holding after an hour, check it in 2. If it's holding at 2 hours, check it in 3. It will be a play by ear thing and anything goes! DO NOT add any stabilizer to the pool until you are nearly complete! The only thing you will be checking for is FC and CC until your CC's are down to nearly 1ppm and you can change the sand, keep SLAM'ing and then finish it off with an OCLT and stabilizer.
    Don't forget to take pics! You may need more Clorox!
    Jun 2014
    Eastern Tennessee
    10
    I tested the pH when I got home and it was 7.2. So, let the process begin!
    I added 4 bottles of bleach to the pool.
    This is a picture right before I added the bleach:
    These are some pictures right after I added the bleach (Pretty Colors! ):
    Jan 2013
    Houston, TX
    1,079
    Wow! This will be a fun thread to follow.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    Jun 2014
    Eastern Tennessee
    10
    Well, I've added bleach two more times an hour apart to raise FC back to 15 ppm.
    Here is a picture of the pool now:
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    Looking good. I helped my sister with hers. Don't worry about testing for cc's until you FC starts to hold. Just know that you WILL have cc's. It will save on your regents. Sounds like you have a good game plan going. The better you can maintain it the faster it will go. Just remember it will take time so keep after it. It will be well worth the trouble to be troublefreepool down the road.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Jun 2014
    Eastern Tennessee
    10
    Thanks for the info! How long did your sister's take to complete? How often were you adding bleach?
    Casey's Avatar
    SW PA
    10,427
    And let the fancy colors begin!
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    If I remember right it was right at a week from start to OCLT. It started to hold somewhat about 10 hours in. We ran the filter in bypass at night because of the pressure rise. We hit it like your plan. Every hour until it started to hold then 2 and so on.
    Jun 2014
    Eastern Tennessee
    10
    Good deal. Tomorrow is supposed to be mostly cloudy so good day to hit it hard. My FC hasnt decreased much after the first test.
    I added enough bleach to get to 15 ppm each time each hour. The first test showed FC 1, the next showed FC 12, and the next showed FC 13.
    I was expecting a much higher decrease with each test.
    Jun 2014
    Eastern Tennessee
    10
    As of this morning I've used 19 jugs of bleach. I am just going to be dosing once in the morning and a few times in the evening since the sun will not be shining on the pool during these times.
    I tested the water this morning and had an overnight FC loss of 3.
    Here is a picture of the pool this morning:
    Hopefully, the conversion will be complete next weekend.
    On a side note, I went ahead and bought 77 lbs of 20 Mule Team Borax to add after the conversion is complete and the water is balanced. Will be buying the muriatic acid that goes along with this process when I buy the CYA later.
    Oh, and I almost forgot, I ordered one of those magnetic Speedstir things! Can't wait for it to come in. I should have bought one to begin with. They look so cool and fun to use.
    Jun 2014
    Eastern Tennessee
    10
    Up to 32 jugs of bleach now. The pool is looking better every day.
    Here is a picture of it yesterday. You can see the bottom and the water is relatively clear. Has kind of a radioactive green color to it.
    Here is a picture of the pool today. Less green than yesterday.
    Butterfly's Avatar
    South Carolina
    10,045
    okie dokie , things are coming right along and pics are great
    Jun 2014
    Eastern Tennessee
    10
    Pool is looking good. Going to perform an OCLT tonight and see where I'm at.
    Here's a picture of it today:
    Jun 2014
    Eastern Tennessee
    10
    All finished with the conversion! Changed the sand out yesterday and added the CYA. Used a total of 42 bottles of 8.25% bleach.
    Here's a picture of the pool with the used bleach bottles put to good use
    I also just added the borax tonight to get the borates up to 50 ppm. Looking forward to seeing how they affect things.
    Casey's Avatar
    SW PA
    10,427
    Congratulations! Love the pic!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,983
    Quote Originally Posted by nick765 View Post
    Great shot
  20. Back To Top    #20
    Jul 2013
    Brick, nj
    1
    Congrats on your conversion! I switched from baqua-sh*t a few years ago (before finding this amazing site) and I regrettably, never took pics. I love the final shot of the TFP bleach bottles!
    19200k gal IG vinyl lined(new liner& fittings in 2011, underground pipes replaced in 2002) 24" Hayward sand filter w/ 1hp Hayward super pump. Zodiac G3 auto vac. Taylor k-2006 kit
