Thread: Pool/Spa Automation Recommendation - possible DIY
    Hi TFP Community!
    I have a Compool 2000 (very old system) that is now starting to give issues. I'm in need of some recommendations on a replacement system and whether it's something I could tackle on my own or not. Someone recommended the aqualink/iaqualink system which sounded interesting allowing me to control from a smartphone. Here's my setup that I think is relevant to the system:
    main pump (single speed) - probable upgrade to variable speed in future
    booster pump
    valve to control flow to pool or spa
    1 light in pool
    1 light in spa
    waterfall pump - currently out of service
    spa air blower - also currently out of service
    solar/gas heater valve - currently broken, I just manually turn it - not terribly important to auto control
    Thanks for your input!
    Casey's Avatar
    SW PA
    10,438
    Re: Pool/Spa Automation Recommendation - possible DIY
    I'm not sure Snoopy but I'm sure someone can help you!
    Aug 2011
    Middle TN
    83
    The answer probably depends on what you want the system to do, what your budget is and how handy you are.
    18 x 36 Vinyl Inground, Coverstar Cover, 2 speed Pentair Pump, Hayward 425 Sq Ft Cartridge Filter, Hayward Heat Pump, Prologic PS8, T-15 Salt Cell, 2 Colorlogic LED lights, TF-100 Test Kit
