Thread: pump will not prime
    pump will not prime
    Hi Guys, I have a friend with a Sta-Bilt 3/4 horse and it will not prime. The pool is full to the overflow, I have check all fittings nothing loose or cracked. Line from skimmer not stopped up. I removed the cover and the discharge line. Filled the pump and turn it on. It pumps very little but the garden hose supplies more water than it will pump. I have the pump housing separated and nothing is broken or clogged. There is no water leaking. I am at a loss. Please help. Thank You
    Playas Del Coco, Costa Rica
    36'X16' in-ground. 25000 gallon
    3/4/HP Hayward with 280 pound sand filter
    AquaRite SWG
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,600
    Re: pump will not prime
    Is the impeller broken or clogged?
    If it's old, it could be the motor. How hot does the housing get? I had to replace mine because the pump would overheat and shut off quite frequently.
    That impeller needs to be able to easily spin. Check inside the translucent impeller cover to see if any of the fins are damaged.
    Nothing broken or clogged and motor runs fine
    AquaRite SWG
    Is the return line clogged?
    Quote Originally Posted by Tyrone Shuz View Post
    No disconnected
    AquaRite SWG
