Thread: leaking pump, do I use lube on the o ring
    May 2014
    Indiana
    2
    I have a leak, right where the pump and the strainer basket join together, there is an o ring that fits in there, It is a doughboy powerline 3047, should I use lube on the small o ring
    38,237
    Re: leaking pump, do I use lube on the o ring
    Welcome to TFP!!!
    Yes you should lube any of the o-rings.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,565
    With any luck, it won't be a shot shaft/mechanical seal.
