Thread: Cloudy Pool
    Jun 2014
    Landisville, PA
    15
    Unhappy Cloudy Pool
    Hi, I'm new to this forum and looking for help. My pool is cloudy. Very much so in the deep end. Pool is 23000 gallons, in ground. Sand filter. Vinyl liner. Water specs:
    FAC 7
    TAC 7
    CH 250
    CYA 35
    TA 100
    PH 7.2
    Copper 0
    Iron 0
    TDS 300
    Pho 100
    I use Chlor Brite granuals, 3 inch tabs in skimmers occasionally, I also use liquid bleach to shock, but water has been cloudy for two weeks. Not sure what to do next. Thanks for any help. Appreciate it.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Cloudy Pool
    Welcome to TFP
    You will need to follow the SLAM process in Pool School and need to confirm the CYA level before you start.
    The best thing you can do is order one of the recommended test kits. The fav around here is the TF100, see link in my sig. Best bang for the buck. Recommended Test kits comparisons in Pool School.
    You should stop using stabilized chlorine and only use bleach/liquid chlorine for the SLAM process.
    Pool School button top right of each page. Post back with any questions you have and we'd also love to see a pic of your pool
    You're done SLAMing when:
    Jun 2014
    Landisville, PA
    15
    Re: Cloudy Pool
    Thanks for your advice. Pool is clear now. Turns out, I still had a glob of pine needles and leaves in the middle of the deep end that I couldn't see. Got them out with a leaf rake and added bleach to the water. All good now!! Happy Happy!!
