Results 1 to 8 of 8
Thread: Cya test results huge variation!
    Jun 2014
    Palmdale/ca
    7
    Leslie's has been telling me my CYA level is off the charts and I need to drain my pool. Went to an independent pool store and they tested my water and show my CYA level at about 40, with two different test kits. So who do I believe?
    Independent store is where I bought my current liner, that appears to be stained light green and they now tell me it's been discontinued because they tended to stain easily, grrrrrrr!
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Cya test results huge variation!
    If you had your own kit and tested yourself, you'd know for sure. Pool store testing is terrible.
    Isolated Spa - 345 Gallons
    Feb 2014
    Central Minnesota
    5,080
    My answer was snarky but true. Describing what type of testing each store did might give results more weight. But home testing with one of the kits recommended here is more trustworthy.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What JVTrain said is true, the CYA test is the one that pool stores tend to get the most wrong, it really takes time, patience and proper lighting to get right, and pool stores tend to have none of those three. So I suggest you get your own quality test kit, I use the TF-100, see my signature for the link, then you can test it yourself and repeat the test if necessary until you are confident in the results.
    Ike
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    This sort of sounds like the guy who just had his freshly filled pool water tested and they said he had 59 CYA straight from the tap!
    Here it is: http://www.troublefreepool.com/threa...33-Fresh-water
    Do it yourself and save!
    Jun 2014
    Palmdale/ca
    7
    Test Strips vs Reagent type tests? Two different brands of test strips showed 30-50 range for CYA and Leslies reagent-type test showed 100+ and said that the test topped out at 100. Shouldn't they at least be in the same "Ball Park"?
    38,285
    Ideally, yes. In reality, no.
    Use an appropriate test kit yourself and trust that.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    I have to agree with everyone else here. I've used test strips (on a hot tub back in the day)...they are unreliable. Sometimes they are accurate and others they aren't.
    Pool store testing accuracy has many variables. Way too many for this science geek. If you get one of the recommended test kits per this forum. You will be able to trust your results. you won't have to second guess anything IMO. Keep the test kit inside when not in use so nothing gets too hot/cold and you'll have success.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
