Results 1 to 11 of 11
Thread: second season with BBB
    elainerader's Avatar
    Apr 2013
    Columbia, MS and Blue Ridge, GA
    120
    Hi all,
    Test as of 30 minutes ago:
    (25Gal in ground pool, vinyl)
    FC 1.5
    TA 60 (it was 70 last year)
    CYA 20 (it was 60-70 last year)
    PH 7.8
    CH 50
    I have small amount of algae present (of course at this FC level I would) Lots of rain lately. My pool is full sun all day. (when it's not raining
    It's not holding chlorine. I have not shocked, but added 2-4 gal of 8.75% bleach every other day and still have low FC.
    This is my second season with BBB . I have lower TA levels and lower CYA levels than all of last year. I would like to know if I have to also address these other levels. They seem on the low end of acceptable but are different than all of last summer when my pool was perfect.
    I know I have to shock to get rid of the algae, but should I raise the CYA and TA before shocking?
    Thanks for any help
    25K GALLON IG VINYL
    LASER SAND FILTER, Hayward SP2610X15 Super Pump 1.5 HP Pool Pump
    UNDER WATER LIGHT
    14 YEARS OLD, LINER 5 YRS OLD
    Mar 2014
    Las Vegas
    288
    Re: second season with BBB
    Quote Originally Posted by elainerader View Post
    Hi all,
    Thanks for any help
    Must get real crowded in a pool that size. I couldn't resist. I would bump the CYA by no more than 10, lower the pH to 7.2 and Start the SLAM process.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Apr 2013
    120
    Quote Originally Posted by jmbradwell View Post
    Hahaha!!! That's funny, my bad......25,000 (just for the record
    Thanks!
    25K GALLON IG VINYL
    UNDER WATER LIGHT
    Butterfly's Avatar
    South Carolina
    10,045
    What is CC?
    I suggest you do not increase CYA until CC is reported. You had a huge CYA loss.
    You're done SLAMing when:
    Apr 2013
    120
    I hate to sound like an idiot, but CC is combined chlorine? How do you test for that? I have my whole testing kit and I have never tested for it because I don't see a test for it.
    25K GALLON IG VINYL
    UNDER WATER LIGHT
    May 2014
    Worcester, MA
    29
    What test kit do you have? Generally you test for FC and write down that reading. Using that test sample you would add another reagent and check the results which would be total chlorine.
    You then subtract FC from that to give you the combined chlorine reading.
    CC=TC-FC
    John
    IG 33K Gallons 20'X40', Hayward Pro Series Sand Filter S310T2 (zeolite), Pentair Intelliflo 3HP SVRS Pump
    Butterfly's Avatar
    South Carolina
    10,045
    Scroll down to post #4
    http://www.troublefreepool.com/threa...Kit-Directions
    Apr 2013
    120
    Hello again......
    New test results (and if I had read the FC test all the way to the bottom it clearly stated how to do the CC test....thanks!)
    CC .5
    FC 5.5
    PH 7.5
    TA 60
    CYA 0
    I have to raise my CYA from what I imagine to now be 0 to 70 (filled the tube all the way to the top and can still see a blurry, but there, black dot)
    I have a full sun all day long situation and my CYA should be, and was last year, 70.
    The PoolMath chart says I need to add 239 oz of dry stabilizer.
    I still have to shock, do I have to wait until the stabilizer is registering before I can continue to shock? (you say it takes a week to show a proper reading)
    Thanks
    25K GALLON IG VINYL
    UNDER WATER LIGHT
    May 2014
    Current: Singapore Previous: Clayton, Victoria, Australia
    584
    Do not add all the stabiliser if you have not already done so.
    If the dot is blurry in any way, it means you have *some* CYA, but less than 20.
    Since you have algae, you will need to SLAM your pool - we don't use the word "shock" because it is not a one-time application of a product, but rather a continuous process.
    You need lower FC (and therefore less bleach and $$$) to SLAM at CYA 20 than at CYA 70. (See the Chlorine/CYA chart)
    You mentioned you have been adding bleach, with the high CC reading I suspect you had the CYA to ammonia conversion, this confirms you need to SLAM.
    Last edited by Abigail K; 06-18-2014 at 05:48 AM. Reason: Mis-read FC and CC levels
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, as Abigail said, you do not want to add CYA to raise to 70 until after the SLAM is completed.
    If you are losing too much FC to the sun during the day, you could add enough CYA to reach 30-40ish via sock method.
    When CYA has dissolved from the sock (squishing the sock helps) consider it "in" the pool and adjust your FC values accordingly. But, don't test for about a week.
    I do not think you had CYA/ammonia conversion since you only reported .5CC.
    Your #'s are fine to start the SLAM. Use a SLAM FC level of 10FC. Start SLAM.
    After you are done w/the SLAM, you could raise the TA a bit.
    May 2014
    584
    Quote Originally Posted by Butterfly View Post
    Good catch, I mixed up the FC and CC values.
