Results 1 to 18 of 18
Thread: New to this...update w/pics
    Ok, here are the basics:
    Taylor kit
    Cya 100
    Ph 7.3 (1 drop to 7.4)
    Total alkalinity 140
    Calcium hardness 340
    6.2ppm free chlorine
    0.6 ppm CC (maybe up to 1.4 as every time I let it sit it started turning pink again)
    In ground pool with pebble tec type surface
    Approx. 30,000 gallons
    Pool is 90 degrees, has solar panels and a solar blanket
    Cartridge filter
    And we keep getting those darned green algae blooms! You can see we added chlorine, but now what? We even added the algacide 2 days ago. Arg...so frustrating.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,575
    Re: New to this
    Algacide is only recommended as a preventative, not a killer. And it shouldn't be required in a properly maintained pool. Your cya is way too high for your level of FC and will require draining in 3rds to lower it to avoid those "blooms".
    Mar 2014
    Las Vegas
    288
    Re: New to this
    Welcome to TFP and congrats for having a good test kit. CYA is high making it harder to get rid of the algae. I see a partial drain and fill in your future. FC is low for your CYA level. Read through Pool School and ask lots of questions. I've seen MANY a green monster slain on this site.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: New to this
    Yep, you have yet another case of sky high CYA, we are seeing many cases every day around here lately, which is somewhat surprising this early into the swim season.
    Ike
    Re: New to this
    We are draining about 25% of our pool to start. I will retest again tomorrow.
    Re: New to this
    Ok...newest test readings
    Jun 4, 2014 Jun 5, 2014 Jun 6, 2014
    CYA 100 60
    Ph 7.3 7.2
    Total alkalinity 140 120
    Calcium 340 310
    FC 6.2 12.8 8.4
    CC 0.6 0.6 0.6
    Pool is still greenish. I am not sure how to get rid of the algae but keep the pool usable for the kids. It is supposed to be 100 degrees this weekend!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: New to this
    You need to follow the SLAM process in pool school, for a CYA of 60 this will require raising your FC up to 24 ppm and maintaining it there until it is clear. No one should swim while doing the SLAM process, but also no one should swim with the way it is now.
    Ike
    Re: New to this
    Now what? It looks clear, not losing chlorine at any sort of crazy rate, but the CC is still 1. Do I keep slamming until CC is .5?
    Here are last night and this morning/late afternoon levels:
    9:43:22 PM
    FC22.5
    6:48:22 AM
    FC23
    CC1
    5:17:11 PM
    FC20 (did not add chlorine all day and left the cover off)
    CC1
    Before:
    Today:
    And the deep end (8')...I think some of that green is actually the tree's reflection:
    Butterfly's Avatar
    South Carolina
    10,045
    Re: New to this
    Yes, continue to SLAM until you meet three criteria that determine when you are done. See red lines in my sig.
    You're done SLAMing when:
    Re: New to this
    Quote Originally Posted by Butterfly View Post
    Just wanted to make sure there was no other reason for CC not going down to .5. Thank you.
    ComputerGuyInNOLA's Avatar
    Oct 2012
    Mandeville, Louisiana
    604
    Re: New to this...update w/pics
    I believe the CC test will turn pink of you let it sit for a few minutes. Don't wait for the results.
    Gunite/Plaster pool at 13k gallons. All Jandy with CL340 series cartridge filter, 1.5 HP Jandy Stealth pump. Jandy 1400 SWCG and PDA4 controller. Dual waterfalls. Polaris 280. Pool installed August 2012. Southern Louisiana. And lets not forget my trusty TF100 test kit!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You are likely getting close, make sure to scrub and look for places algae might be hiding, in recesses, under ladder steps, etc.
    Can someone please give me an idea of how long this takes? We have been doing this for one week as of tomorrow, chlorine was steady today, CC won't budge. I keep sweeping, it looks clear, but I do see some cloudiness when sweeping.
    I am getting a bit worried because we leave for vacation in a few days for a week. Ugh. I bought phosphate remover to use as a preventative while we are gone, but if I cannot get it balanced first will I lose all my hard work?
    Casey's Avatar
    SW PA
    10,427
    Please update us with a full set of test results.
    Also, perform the OCLT tonight and re test in the morning at 5am and report those test results back.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    If you're going to be gone for a week, a metals-free algaecide like Polyquat-60 is a better option as preventative in an already clean pool. Phosphates are meaningless with adequate FC.
    I'd have someone add some bleach while you're away if possible. Trichlor pucks would be an option but your CYA is pretty high already.
    Isolated Spa - 345 Gallons
    The frustrating part is I don't know how well I am testing. So, last night hubby told me FC was 21.5. This morning I finally stopped at 25. Here are some pictures (because I kip don't know how well I am seeing the shades of pink!).
    Original water sample:
    FC 25(?)
    CC after 1 drop
    CC after 2 drops
    Does it look ok to stop slamming?
    Never mind, CC went up to 1 this afternoon. I guess i am still not done. It will be interesting what it does when we leave for vacation.
