Thread: Hayward Sharkvac - Shark Vac - does it learn your pool shape
    May 2009
    St. Louis, MO
    45
    I recently bought a Hayward Shark Vac. I believe one of its advantages is that it lears the shape of your pool, and then becomes more efficienct with coverage. My question is, is this learning cumulative? A cleaning cycle is 2 hours -- does it learn during this 2 hours, and get more efficient, and then start all over the next time? Or, does it retain its learning, and use this as a starting point for its next cycle? So will the cleaner get better with time, or is each cycle the same?
    30,000 galllon, inground, vinyl liner, L-shaped pool
    1.5 hp pump, sand filter, heater, run pump 24/7
    Aquarite salt system
    St. Louis, MO, USA
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Hayward Sharkvac - Shark Vac - does it learn your pool shape
    From what I've read around here, "learning the pool shape" is really not all it's touted to be. It doesn't have any way to sense where it is in the pool, after all. As long as you're happy with how it cleans, don't worry about it!
