Thread: ok to add acid directly?
    Jul 2012
    Whidbey Island, WA
    397
    Hi
    So add muriatic acid from time to time
    Is it Ok to add it directly or ought it be diluted first?
    Thank you
    IG under fir trees and one cherry surrounded by grass built in 1979, 30k, plaster, old Sta-Rite HRPB30, 4.9 sq.ft, 20 GPM/sq.ft., but with new glass, new (in 2012) 1 HP WhisperFlo one speed, new (in 2013) Rainbow tab chlorinator attached at the top, old Maxi-Flo Heat Exchanger MF-260, Burnham V7 oil heater 245 MBH, new (in 2012) Compool to Easytouch, Taylor K-2005 and TF-100.
    Mar 2014
    Las Vegas
    288
    Re: ok to add acid directly?
    Add it directly in front of a return jet. Slowly pour it in just above the surface and rinse your cup. No need to handle it twice by diluting.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    I second the direct approach. get low to the water so as to reduce any splashing.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    freqz's Avatar
    Sep 2013
    Dallas, TX
    116
    Quote Originally Posted by elwood58 View Post
    Make it three.
    Wear gloves and glasses.
    25000 gal in ground plaster. '79 vintage. Cartridge filter.
