Thread: Re: Aquarite Not generating - lights not on
    Jun 2014
    adams
    1
    Moved from http://www.troublefreepool.com/threa...-not-on/page14 Butterfly
    My soldering gun is not doing its job and now i have nothing but a knub after trying to heat up the solder and pull the old wire out. Has anyone dared to drill out the old wires?
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    I don't think that sounds like a good idea. Is your iron not melting the solder? Have you tried wicking it out?
    Jun 2014
    Humble, TX
    2
    My Aquarite had no power. Noticed the round black thing or resister was burned. Ordered the part from Digikey and had a guy replace it. Power came back on but was not generating. I have the power light and the no flow light on. Also when I turn the pool off, the system will still display for 10 seconds. Anyone know what's going?
    Sep 2007
    Guelph, Ontario, Canada
    60
    Thanks for the link to the closed thread.
    Saved me a couple hundred bucks.
    Carl Schnurr
    Pool: 96,000 litre, vinyl liner, 1 HP pump, sand filter, Aqua-rite SWG, Hayward e.vac, installed 2005
    Spa: La-Z-Boy 'Relieve', 1300 litre, acrylic, with ozonator, installed 2017
    Test Kit: Taylor 2005C
