Results 1 to 7 of 7
Thread: Whats the correct order of getting my water ready for a 'new' pool install?
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    I'm filling my pool as I speak.
    I have a SWG....so i know i need to add my salt.
    Do I adjust my CYA first...get my ph balanced and then chlorine....and THEN add salt?
    Is there a specific order i should go in?
    Thanks gang
    Intex 16'x48" Ultra Frame
    Intex 2,650-Gallon Sand Filter Pump
    Intex Krystal Clear Saltwater Filtration System
    Taylor K-2006
    Re: Whats the correct order of getting my water ready for a 'new' pool install?
    The first step is always a full set of water test results (except CYA). After that, it depends on the test results.
    Salt doesn't affect anything else, so you can add that any time once the pump is running. Also, the first day only you add 2 ppm of chlorine after sunset.
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    After the pool is full, i'll come back with my test results, thanks! ...could be a few more days...lol
    Taylor K-2006
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'd suggest you hold off on the salt until the water is all balanced and running as a bleach pool. Then hold Diamond Day when you add salt. Read Post 5
    nate81's Avatar
    May 2013
    Raleigh, NC
    190
    Genius. Thank you. My 5 year old will love this!
    ninja edit: San Dimas....i cant help but think of Bill and Ted lol
    Taylor K-2006
    Mid Missouri
    227
    I have an Intex I put up every year. Chlorine should be added manually to the appropriate levels with bleach starting on fill day. Over the course of the next day or two you can work towards switching over to your SWCG.
    Pick the CYA level you want so you can determine the appropriate chlorine levels to maintain as you go. I use the liquid instant product and I use 60ppm. I just add the appropriate number of oz per the manufacture to hit my number.
    So starting on fill day chlorine manually. Over the next day or two get your salt and CYA in while maintains your chlorine level every evening with bleach. By day three or so you should be ready to transition to the SWCG. This is about the time I take a total alkalinity measurement and PH measurement and start correcting and keeping my PH in line. I usually start on the high end of the recommended run time with my SWCG and dial it back to get my chlorine level right where I want it. It's pretty much all gravy from here.
    Mid Missouri
    227
    Oh yeah. If you've got the same SWCG I've got with the copper bars; most folks including myself around here unplug that connector so as to not add the copper to our water. It's not necessary and has some possible negative draw backs.
    I use the Intex manual for the qty of salt. I use the Intex manual as my starting point for the SWCG run time. I use the charts, calculators, and recommendations here for choosing my levels and maintaining my CYA, chlorine, and PH.
    18'X48" Intex Easy Set, 2650 GPH Intex sand filter, Intex SWCG, Intex deluxe skimmer
