Thread: Cleaning filter cartridge?
    samanthamartin777's Avatar
    May 2014
    Jonesboro, AR
    19
    I have this Hayward pump which uses cartridge filters. What's the best method for cleaning the filters? Does anyone use a certain type of cleaner? Or just a bleach and water solution?
    I saw a tutorial for cleaning another type of cartridge here, but it looks much different than mine. Mine looks more like this one:
    24' round above ground pool, 13,500 gallons. Hayward cartridge filter
    Re: Cleaning filter cartridge?
    Just spray the cartridge off with a garden hose set on a tight spray. Then once a year you rinse normally, soak it overnight in a mixture of one cup of automatic dish washing detergent for each 5 gallons of water, rinse throughly again, and reinstall.
    May 2014
    Jonesboro, AR
    19
    Great, thanks Jason! Someone else was telling me I had to use a special cleaner on the cartridge.
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    The special solution usually is for pools with baquacil as the sanitizer. Just one more reason to stay away from products like that.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    patrick3229's Avatar
    Feb 2012
    258
    Also a general rule on when to replace the cartridge would be when the pool filter is clean if your operating psi on your pressure gauges 10 psi higher than when you first put in a new cartridge. For example if you put in a brand new clean cartridge and you note your psi is 8 PSI then 1 year later you take out the cartridge and completely clean it and your operating psi with the cleaned cartridge does not drop below 18 psi then it is time to replace the cartridge.
