Thread: Water feature not all flowing correctly
    Jun 2014
    Orlando, Fl
    7
    New user, first post here. I'm a fairly new pool owner....I bought the house w/ pool about a year ago. Recently the built-in water feature nozzles have not all been flowing correctly. I have a feature with about 30 holes that the water sprays out of. It seems like each hole is getting different pressure or something is clogging them a bit. I have a valve that I can choose to have the return go to the feature or the normal jets. If I direct it to go all to the feature, some spouts are shooting water farther than others. At a lower setting some of the holes are barely trickling the water out.
    Ive enclosed a pic with the return going mostly to the feature to show what Im talking about. Sorry I didnt think to take one with the water off...I can if needed.
    Any ideas on how to get them all to have the same output? Do I need to clean them out somehow?
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Water feature not all flowing correctly
    I use a large paper clip to unplug the holes on my slide outlets.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jun 2014
    Orlando, Fl
    7
    Well, I tried the paper clip. I even tried putting in about 3 feet of fairly thick wire, ala pipe cleaner. And it did fix it at all. Its still exactly the same.
    Any other ideas?
    Jun 2014
    Orlando, Fl
    7
    Pool store told me to try some Scale Free which removes calcium and mineral build up. Still no change at all.
    Come on, someones gotta have a suggestion...
    Apr 2013
    Sacramento, CA
    2,769
    Any idea of the brand or manufacturer? If you know it see if they have a customer service line. I would try to detach it from the wall and soak in vinegar for a few hours. or figure a way to use wet towels and soak in place. Test it first to see if it deforms the plastic.
