Thread: Is water clarifier needed after SLAM?
    May 2014
    Illinois
    10
    I just slammed my green pool the last couple nights and I woke up to clearness with no cloudyness from what I can see. Should I still use a water clarifier or just leave it as is? I'm just not sure if a clarifier should be used to catch whatever I can't see or if it's fine.
    32'x16', 14K gal, AG vinyl, sand
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,985
    Re: Is water clarifier needed after SLAM?
    Leave it alone. Clarifiers are a desperate measure used by desperate men.
    And you're not done with the SLAM until you've passed all three tests. Clear is only the first one. Second is the CC reading. Third is the overnight loss test. Until you've passed all three, keep the FC at SLAM level and the filter running and don't forget to brush.
    May 2014
    Illinois
    10
    Will do, I gotta get to brushing, thanks!
