Results 1 to 9 of 9
Thread: What do I do now?
    May 2014
    Burlington, NC
    45
    What do I do now?
    I just received my Taylor K-2006 pool test kit in the mail and have had fun getting my first readings. They are:
    FC=2.5 ppm
    CC=1.0 ppm
    pH=7.1
    TA=70 ppm
    CYA=30 ppm
    CH=160 ppm
    The pool is a pretty blue but still can't see the bottom of the shallow end. Should I just do the Pool Math and add from there or should I SLAM? Sure want to swim by this weekend.
    Thanks in advance.
    18,000 gallon IG vinyl
    Hayward S220T sand filter, replaced sand 2013
    Sta-Rite pump, 1HP?
    New liner, 5/12; pool built in 1981;
    38,521
    Re: What do I do now?
    With cloudy water and high CC, you need to go through the SLAM Process ... better start quick
    May 2014
    Burlington, NC
    45
    Can I start that effectively in the time I have left this afternoon? It is 3:30 p.m. my time.
    Sta-Rite pump, 1HP?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    The SLAM process works best in darkness, so definitely! It really depends on your schedule and how much time you have available to monitor the FC level. Read through the process a few times.
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    May 2014
    Burlington, NC
    45
    How long will it take me to get the pH up? If I add the Borax calculated by Pool Math to get it up .1, how long do I wait to retest it to make sure it is at the right level?
    Sta-Rite pump, 1HP?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,071
    Quote Originally Posted by mamalou23 View Post
    7.1 is close enough. Don't delay fussing with the pH. Just get some bleach in there.
    May 2014
    Burlington, NC
    45
    Also please help me understand the Chlorine/CYA chart? What does shock FC of 12 mean? Do I put that number in Pool Math target to know how much liquid chlorine to put in?
    Sta-Rite pump, 1HP?
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Yep, you got it! Under "Now" put 2.5 and under "Target" put 12.
    May 2014
    Burlington, NC
    45
    Great! Thanks so much.
    Sta-Rite pump, 1HP?
