Results 1 to 8 of 8
Thread: pH still going up
    Jun 2013
    Southeast Pennsylvania
    125
    pH still going up
    Hi all,
    I am going on vacation soon and I am concerned on what to do with my pool while I am gone. The pool is a new start up and I should be fine with everything except pH. The pool is new, 5/5, and the pH rises daily. I have a 13,500 gallon gunite and I add anywhere from 12-24 oz a day. What can I do while I am away?? I'd rather not have neighbors come over, but there are pool owners in next door and two doors down. Isn't there something that will leach out slowly a pH down so the pH will be maintained while I am gone??
    Doug
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: pH still going up
    Trichlor pucks in a floater will maintain chlorine and lower pH. But they also add CYA.
    38,463
    You could try floating the trichlor tablets, assuming you have the wiggle room for the CYA rise. They would at least help the pH some.
    Jun 2013
    125
    I've been on trichlor tabs for 4 weeks now.....just until I go to salt on 6/9. So, I'm not sure this is going to do it.
    Mar 2011
    Houston, Texas
    413
    When I went on vacation during the first year of my pool, I had someone (my daughter) put the correct amount (use your best estimate) of dry acid (pH down) in the pool. It's easier than adding MA for someone not used to adding chemicals to a pool. I don't see that you have much of a choice other than to ask a friend or a neighbor to come by one or twice while you are out of town.
    That said, how long will you be gone? A question for one of the experts: will 7-10 days of high pH really mess up one's plaster?
    9,200 gal. Gunite Luna Quartz French Grey pool with spill over spa, two fountains on tanning ledge (rarely used)
    Pentair Whisperflo 2HP, Pentair CCP Cartridge 420 Sq. Ft., Polaris 280 with booster pump
    Pentair EasyTouch 4, RayPak LoNox 266k Natural Gas heater, Aqua Rite SWCG T Cell 9, Borates, TF-100 test kit
    Jun 2013
    125
    I'll be gone for 7 days. My pH is 8 every morning I test. How do you apply pH down?....Do I need to dissolve that a bit or can the powder just be thrown in??
    May 2014
    Worcester, MA
    29
    Click on "Pool School" then "Pool School Index" then "Recommended Pool Chemicals" It will give instructions on adding various chemicals to your pool.
    John
    IG 33K Gallons 20'X40', Hayward Pro Series Sand Filter S310T2 (zeolite), Pentair Intelliflo 3HP SVRS Pump
    Mar 2014
    Las Vegas
    288
    I haven't read the label for pH Down but from what I understand it is nothing more than MA that has had a very expensive label added to the bottle. MA is much cheaper.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
