Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 83
Thread: New-b.. Not sure what to expect?
    Jun 2014
    Evansville, in
    44
    Okay.
    Welm have an intex 18x48 above ground.
    We set up 2 weeks ago, we followed the htp instructions. Lowered the ph according to strips, then added 3inch puck in the floating dispenser. As I started online digging I wanted to try the. bleach method.
    According to those strip my levels are
    Ph: 7.5-7.8
    Ta: 150ish
    Th: 200
    Cya: 30-50
    now my fc was not reading right away so I added, enough according to pool calculator, to hit 4-5.
    Problem I'm having is holding that number. I dump bleach at night, test in the morning @2/4-3/6 mark, by the end of the day I have no reading at all. So from 9-5 its gone. Rather the kids are in it or not. It in full sun till about 3pm. I'm aware I have to add chlorine often but with that puck floating should I really have to be adding that much a night? It's getting pretty pricey.. What am I doing wrong? Low cya, or algae?
    I'm aware I need a new test kit, what's the best for my situation?
    My husband insisted on going to leslies which they said I need more cya, I really don't want to do that knowing I have to up the chlorine to keep up. Since its only 2 weeks old is it just not self stabilized yet? Ahh! I honestly have no idea what to expect. Help a busy mommy of 5 boys out! I didn't want another chore
    38,275
    Re: New-b.. Not sure what to expect?
    Welcome to TFP!!!
    Test strips are worthless and provide advice based on strip results is not a good idea. These are the Recommended Test Kits.
    Have you added any stabilizer or just the tablets? How many? Likely your CYA is too low and you are losing all the FC to the sun everyday.
    How much Pool School have you read? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Jun 2014
    Evansville, in
    44
    No stabilizer, since it turned the color instantly (when I tested tap water it did not) I didn't want to over do it. This Site has me terrified of the pool supply store so I didn't want to listen to them either lol..
    How much should I add? Is the htp from walmart ok?
    I will order my tests tonight.
    Jun 2014
    Evansville, in
    44
    It was the cya 30-50 mark btw.
    38,275
    Did you use any powdered chlorine? How much? How many tablets have dissolved?
    The stabilizer from Walmart is fine. Use PoolMath to calculate how much you need, although, I am not sure where you are starting to know how much to add to get to 30ppm.
    Jun 2014
    Evansville, in
    44
    So is it possible I'm not at the 30-50 mark? Should I have leslies pool test it to see?
    No powdered chlorine just bleach.
    1 tablet almost dissolved.
    Mar 2014
    Las Vegas
    288
    Quote Originally Posted by B.Love View Post
    Sent from my PantechP9090 using Tapatalk
    With only one tablet, I would guess that you are at real close to 0 CYA. I would add some CYA to the pool. Use pool calc to determine how much you need to get to 25 assuming you have 0 now. Once you get your test kit, test the water and slowly bump it up to where you want it.
    12000 Gallon IG Plaster built 2/15/2014. Jandy 340 sg ft 127 gpm filter, Jandy 1 HP stealth pump. Circupool RJ-45 SWG (overkill). TF-100 with Speed Stir.
    Jun 2014
    Evansville, in
    44
    Okey dokey.. I'll get right on it. Thanks!
    Jun 2014
    Evansville, in
    44
    The only place I have is leslies and big chains, walmart target etc. Leslies says to get liquid. Does it matter or is the hth powder good?
    38,275
    Get the HTH powder ... way cheaper.
    With only 1 tablet you have virtually no CYA, I agree with the above suggestion.
    Jun 2012
    Rochester, NY
    247
    Huge surprise!
    Rick
    Installed June 2012 Aqua Leader 24ft Round AG Influence w/54 inch walls 13,500 gallons
    Cartridge Filter 100SF, 1.5HP
    Aqua Plus Smarte System - In for vacations, BBB all the way.
    Love my PVC Solar Cover Hangers
    Jun 2014
    Evansville, in
    44
    Okay I'm about to choke out the husband.. He bought liquid cya, fine. I put in half gallon, then I put in 50oz of bleach last night.
    He still has not ordered my test kit which I'm going nuts about. Instead insisted apon leslies testing it. According to them:
    Cya-50 (I find hard to believe)
    Fc-2.5
    Ph-7.6
    And they are saying that's perfect readings.
    Shouldn't my chlorine be around 5 with a cya of 50 (assuming it's 50)
    My test strips show cya of 30-50 chlorine 3-5..
    I'm trying to be patient and get it through his skull. But in his head we haven't had a problem yet. Yet! What to do?
    Jun 2012
    Rochester, NY
    247
    You'll need that test kit. I wouldn't trust that CYA reading at all, pool store results are almost always wrong.
    You won't be able to do it both ways, either follow the advice here or the pool store.
    Good luck.
    Rick
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Two choices as I see it. Let him deal with the pool his way. When it fails, you get to say "told you so"....Sadly this method will cost you time and money, not to mention the inevitable marriage counseling. . The other way is to have him read pool school. The Chemistry behind the TFPC method is sound. If you look at pool chemistry as Chemistry you'll be much better off. If you think it's magic or voodoo...well...enjoy Leslies. Looking at things in life, there's the easy way and the right way. The easy way is rarely the right way. This is true when it comes to testing your chemicals. Nothing is easier than a strip dip test. They're inconsistent. Some of them are pretty dang accurate, but this changes from lot to lot and tube to tube. (probably strip to strip). That rule is also true when it comes to pucks vs bleach. It's really simple to toss a few pucks in a floater and then pour a bunch of magic powder in your pool weekly....but you're stabbing yourself in the leg every time you do it. Eventually it will bring you to your knees (via algae bloom when your CYA is crazy high and your FC isn't). Using bleach is a bit more involved. you will test and dose daily. It takes a whopping 5-10 mins....but it works. Once you do the bleach method (with a proper test kit) for a cpl weeks it will become second nature. The biggest thing you must avoid is complacency. If you skip on your "job" for a few days, you'll pay.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Jun 2014
    Evansville, in
    44
    Okay the Taylor 2006 or tf100
    38,275
    Are you asking? The TF-100 is a better value due to the quantities of the reagents you get and thus the number of tests possible as shown in the Recommended Test Kits comparison.
    Jun 2014
    Evansville, in
    44
    K got it ordered! I'll let yall know my results when I get it. Ty!
    Jun 2014
    Evansville, in
    44
    Husband got the Taylor 2006c.
    Jun 2014
    Evansville, in
    44
    Okay results
    Fc: 7.2
    Cc: 1.4
    Ph:7.6-7.7
    Ta: 220
    Ch: 140
    Cya: 33?.. Didn't quit understand that one as much.
    Now what?
  20. Back To Top    #20
    38,275
    Read these: Extended Test Instructions
    Check out the YouTube videos: https://www.youtube.com/user/tf100te...e=results_main
    Use 10ml sample for the FAS-DPD test, each drop is 0.5ppm and that is good enough.
    With a CC that high, you need to follow the ShockLevelAndMAINTAIN Process.
