Thread: Pump leaking
    Jun 2014
    Beckley
    2
    Pump leaking
    I got the pro series pool. The hose connections were leaking so I changed out the plastic connectors for metal ones from lowes and that fixed it. Now I see water leaking out from the bottom of my black pump. Any suggestions as to why or how to fix it? Thanks in advance!
    Jun 2013
    Indiana
    57
    Re: Pump leaking
    you may want to post a picture showing where it is leaking.
    IG plaster, 22,000 gallon, Jacuzzi Laser Sand filter
    Jun 2014
    Beckley
    2
    Re: Pump leaking
    It's leaking straight down " out" of the pump. I'm assuming I didn't get it tight enough on there. Gonna try some plastic tape to see if that helps
