Results 1 to 7 of 7
Thread: Just One Cup!
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Just One Cup!
    Bought a bag of ZeoFiber and added a cup to my Sand Filter yesterday. Wow! This morning it looked like somebody stole all the water from my pool. It really seems to have added a new level of clarity.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: Just One Cup!
    Great!
    Watch that filter pressure. Until you get caught up with the backlog, it will load up the filter pretty fast. After that, I'll bet keeping it in there should make that water sparkle all summer long.
    Feb 2008
    Milford, CT
    333
    Re: Just One Cup!
    Is the ZeoFiber effect the same or better than just using a little DE in the sand filter?
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Richard320's Avatar
    Jan 2010
    18,988
    Re: Just One Cup!
    I don't know. I have a DE filter. They seem to work about the same in there. I just like being able to backwash onto the front lawn with the cellulose.
    Aug 2011
    Southern California
    188
    Re: Just One Cup!
    Richard using the cellulose in a DE filter and doing just a backwash (not opening the filter at all), do you re-coat with the same amount as if you did a full cleaning of each grid?
    Richard320's Avatar
    Jan 2010
    18,988
    Re: Just One Cup!
    Quote Originally Posted by Hawk View Post
    No. My filter has the backwash valve integral and under the filter. So I backwash to lose most of it, then open it up and hose off the grids with the valve open and the rest of it washes away with no further disassembly. So every time I use the full amount.
    elwood58's Avatar
    May 2012
    653
    Re: Just One Cup!
    Quote Originally Posted by chrisexv6 View Post
    Seems about the same. ZeoFiber is safer than DE and breaks down naturally.
