Page 1 of 2 12 LastLast
Results 1 to 20 of 32
Thread: Looking to buy our first pool.. Wondering about pricing and options..
    Jun 2014
    Youngstown, OH
    182
    I've done a considerable amount of homework.. I've read that the pump/filter combos the "package" deals give you are usually always wrong for the pool.. We know we want a 24' x 52"/54" and from what I've read I want a 3/4 - 1 HP pump and at lease a 150lb sand filter.. Please correct me if I'm wrong on that..
    I've been to 4 stores and emailing back and forth with a 5th now..
    The Great Escape (More of a national type store):
    Quest 24' x 54"
    Specs:
    Massive 8" wide injection-molded resin top ledges, resist bad weather, chlorinated water and constant wear
    Decorative 8" Krystal Kote steel uprights and resin foot collars give the Quest strength, support and style
    54" high wall finished with Duratex anticorrosion paint protects against humidity and chemicals
    Durable resin caps and boots give the Quest strength, support and style
    Heavy-duty tracks, over-sized connectors and over-sized fasteners add strength to a pool that will last for summers to come
    Oval Yardmore space saving system saves much needed yard space and looks more attractive
    20 Gauge blue liner included with pool price with the option to upgrade to a 25 gauge blue or printed liner
    Widemouth Thru-wall skimmer and water return fitting included
    Wall Color/Design: Champagne/Panorama
    Warranty: Manufacturer's 60-year limited warranty
    Made in the USA
    - See more at: http://www.thepoolfactory.com/quest-...specifications
    Pump / Filter: Hayward 110 SwimPro (Cartridge) with Hayward 2.0HP Pump
    Liner - 25 Gauge liner
    Extras - Solar Cover, Zodiac Knoticki 2 Pool Cleaner, Maintenance Kit, hoses, yada yada..
    Total Price - $3,850 Installed tax included
    BY Pools (Local Pool Place)
    Distinction 24' x 52"
    Specs here: http://www.apollo-pools.com/PDF/pool-distinction_lx.pdf
    Pump / Filter: Hayward S180T 18" Sand Filter and a Hayward 1.0 HP Pump
    Liner - 20 Gauge liner
    Extras - Solar Cover, Maintenance Kit, hoses, yada yada..
    Total Price - $4,050 Installed tax included
    So the differences in the above.. The first pool has the resin ledges, the second has steel. The first pool is 54" the second is 52".. The first pool has an automatic pool cleaner, the second does not.. The first has a 25 gauge and the second does not..
    So all that to say.. The second is more and seems like I shouldn't go with them for the differences noted above.. Problem is, they are local and I would like to buy off them then more of a "walmart" type store.. Are the differences above that big of a deal?
    Then there's the last one I'm still trying to get some good pricing with.. LiteHouse Pools.. They have the pool I want the most (at least I think so).. Basically either of these aluminum pools are nice looking.. Looks like for a similar package to what the above offer its around $4,040 plus tax installed.. Problem is, this place wants to just give a 100lb sand filter (on the website it says 100lb but the sales guy quoted me a FIFTY lb sand filter!!)..
    So, what are your guys thoughts..
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Re: Looking to buy our first pool.. Wondering about pricing and options..
    I have a smaller pool than those you are looking at and a 300lb sand filter, I can't imagine running a 100 lb...they MAKE a 50??
    12 x 28 Doughboy Dinosaur (j/k: Breckenridge) partial bury, continuous depth 9,000gal. Doughboy Power Pak I digital 1hp pump, Hayward Pro-Series 300lb sand filter. Foam panel base, Gladon wall foam, Gladon cove.
    Jun 2014
    Youngstown, OH
    182
    I just asked them if they make bigger and he said he can do a Hayward 150lb with a 1.5HP pump but it would be $100 more.. Is that pump too powerful?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    You just need a bigger filter, not a bigger pump
    Jun 2014
    Youngstown, OH
    182
    Quote Originally Posted by Isaac-1 View Post
    Yea, that's what I'm saying.. When I ask about bigger filters they automatically put in the bigger pump.. So do I want a 1HP pump with a 150lb sand filter?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    It's pretty deep stuff but check out this thread on pumps, filters, piping, etc.
    http://www.troublefreepool.com/threa...lost-your-head
    I suggest reading through and getting what you can out of it but usually smaller HP pump = more efficient, installers tend to oversize pumps unnecessarily. Larger filters mean less cleaning/backwashing and more efficient filtering. But read through it to understand why.
    Isolated Spa - 345 Gallons
    Pigeonlove's Avatar
    Jun 2013
    Boise, Idaho
    102
    Are you able to go with their pkg w/out the filter? Plenty of big Hayward sand filters on ebay with great prices.
    Jun 2014
    Youngstown, OH
    182
    Is there a major difference between a steel upright and a resin upright? IE: One better than the other?
    Jun 2014
    Youngstown, OH
    182
    And another question.. I'm guessing I shouldn't need any of the chemicals in their "package" deal if I'm going to try and go the BBB route, right?
    What about the automatic system (the Frog thing or whatever).. Guessing no to that too.
    Thanks!
    Jun 2014
    Youngstown, OH
    182
    So to clarify.. Is this basically all I should need to buy?
    24' Pool
    150lb sand filter
    1HP pump
    Solar Cover
    Bead Liner
    Maintenance Kit
    Installation
    NO LADDER (get off Craigslist)
    NO CHEMICALS (Going to try BBB)
    NO AUTOMATIC MINERAL SYSTEM (Going to try BBB)
    Am I missing anything?
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I am not an expert on above ground pools, but my understanding is steel will rust, the frog system is a mineral system and will add copper, something we actively advise against, unless you like having green hair, etc.
    Jun 2014
    Youngstown, OH
    182
    Thanks.. I barely have any hair left and it's already starting to gray.. Not sure if gray/green is the way to go so I'll keep that item off the list..
    Another forum recommended this for my pump/filter setup:
    Hayward S220T 22" Sand filter
    Hayward SP15922S Power-Flo Pump
    Thoughts?
    Installed in 2014 - 24' Round x 54" Bliss XL Above Ground Pool 14,090 gallons // Hayward S270T Pro Series 27-Inch 350lb Sand Filter // Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed //
    Installed in 2015 - Hayward H200FDN Natural Guess Heater // K-2006 Test Kit
    Youngstown, OH 44514
    Apr 2013
    Akron, NY
    40
    Have you considered a cartridge filter? I use one in the identical size pool and love it. I bought a 2nd cartridge and just swap them out weekly and hose off the dirty one. Quick and easy. Plus simple to break down and store for the winter.
    24 foot 54 inch AGP, 14.5k gallons, 1hp pump, 120 sq foot cartridge filter
    Jun 2014
    Youngstown, OH
    182
    Well I wasn't sure what to get.. But, all my co-workers have sand and a few others on another forum recommended sand.. So, I just let that be my determination.. Because, honestly, I didn't / don't know what to get!
    Apr 2013
    Akron, NY
    40
    Either way - use this method. Have you experimented with poolmath yet? This will guide you through exactly what to add to the pool as you go. Trust the site - once you are dialed in, the daily maintenance is less than 5 minutes. Just a quick chlorine test and then put in some CL to get to your target level. Every few days throw in a PH test, and weekly run the full set. Thats it.
    Feb 2014
    Central Minnesota
    5,080
    Quote Originally Posted by tbird2340 View Post
    Thoughts?
    The 1 HP, 2 speed is plenty for your pool and the two speed option is nice. You can circulate most of the time on low speed and save money on electric bill.
    That's a good sized sand filter if you choose to go sand. You can always go larger but with a short season that's probably good. Check out Pool Filter Maintenance and Pool Filter Comparison before you decide.
    Jun 2014
    Youngstown, OH
    182
    So I was at a pool place tonight and he said they don't sell 2 speed pumps with sand filters, only cart filters because the low speed isn't powerful enough to go through the sand.. It's so annoying all the false info they give..
    What is everyone's thoughts regarding steel vs resin? I have a pool that has steel columns and a resin ledge.. I also have a pool that has steel ledge and steel columns (this pool has "textured resin coating" applied to the steel)..
    I've just been looking and looking for hours and 5 stores and I still haven't pulled the trigger. I don't know if I'm being too anal or what..
    Thanks
    May 2009
    Mn
    198
    Customer service - how is it at each of the stores? Will they take care of you after the fact?
    I am going to chime in with my experience. I'm not an expert. Our pool is called the Diamond Star, but I think it is exactly the same as the Quest. Personally, I can't imagine being in a 52" wall pool, because I'm tall and just cause the wall is 52, the water isn't. BUT that said, trying to find a beaded liner or a nice liner pattern for a 54" pool is not fun. There aren't as many patterns to choose from and you most likely will have to have an overlap - maybe that is ok for you, but I wanted to point that out.
    Next I'm not so sure I like the resin tops. Yes the pool is truly round, but the resin sags if you walk on it but it does pop back (yeah, I know I probably shouldn't but I have to in order to vacuum it). Not that it will break, it just isn't very solid. Also getting a winter cover to stay on was darn near impossible. We had to get a larger cover because the rail is so wide. We gave up on a winter cover.
    Next, make sure that they install it correctly. We got ours from a "big Box store" formerly called Watson's. They sub out the install and they did it WRONG. The blocks were too small for the uprights and they put it all on sand instead of sinking the blocks into the ground. Had they done it correctly, I think our pool would still be standing today, but because of the freezing and the sand, everyone of the bottom plates was broken. If it had been metal, they might have withstood the force...but I can't say for sure.
    Now the nice thing about the resin...NO RUST! there was a little bit of corrosion on some of the uprights and wall but having the resin rails is really nice and gives a piece of mind that this pool will stand for a long time.
    So, It is a personal choice. I am happy with our pool despite some of the limitations of the liner choices and the saggy top rails. My sister has a pool with steel rails and they are totally bent and dinged up. Plus the pool has jagged lines and I like that ours looks like a perfect circle.
    As far as the "package" goes, I'd take their basic, sell the stuff on e-bay or craigslist and get your own. Unless they sell a name brand sand filter (Hayward, pentair, etc.). You can get a nice 2 speed pump for about 300.00. Depending on your electric rate, it should pay for itself quickly. We saved 100 per month with the switch (we run 24/7 because of the heater). We got our own cartridge filter because our water is so bad. Every time I backwashed, I'd have to add a little water, which is more chemicals - iron out and muratic acid. I just didn't want to mess with it.
    Good luck with your decision. It is tough, but in the end, I don't know that you can make a bad choice with a permanent above ground pool. The equipment can always be changed.
    24' Round Diamond Star, 54" wall height, 200sq ft sta-rite cartridge filter
    Dynamo 1hp 2 speed pump, 199k Rheem milivolt heater
    Pool rover jr. - our best friend!
    Tf-100 plus borate strips and Taylor k1000.
    Jun 2014
    Youngstown, OH
    182
    Ok bought the pool! So glad this is done with! I bought it without the pump and filter and plan on getting the ones that I linked on here.. One thing though.. I will have to get all the hoses and fittings.. Not a big deal.. Just need to figure out what I need..
    Also, I get no plastic "pad" since I'm buying separate.. I liked those because they had outlines of where the filter, pump, and feeder system would go (even though I'm not going to be really using the feeder system - I did get it in the package and may use it when on vacation and what not)..
    What do you guys do if you don't get that plastic pad? Do they sell those? They seemed to be pretty specific to pump/filter combo.
    Thanks!
  20. Back To Top    #20
    Jun 2014
    Youngstown, OH
    182
    So if I'm going to go sand.. What size filter? 250lb enough? Too much? And I know I want a 2 speed pump.. Anyone recommend one other than the one I linked earlier?
    Thanks!
