Page 1 of 3 123 LastLast
Results 1 to 20 of 43
Thread: Converting from SWG to Chlorine pool?
    May 2012
    Flower Mound, TX
    130
    I'm trying to convince my friend to take his green pool to a higher level, TFPC method!
    He has a SWG, but it's inoperable. He is trying to operate the pool by chlorine, advise by Leslie's Pool. I want to get your advice before he ask me to help him.
    John
    14,000 gallon IG DiamondBrite pool with 2 ea. waterfalls and slide, Hayward Tristar 2.0 HP 2-speed pump, Hayward 3/4 HP waterfeature booster pump, Hayward 48sf DE filter, Hayward PS4 wireless controller, 1 skimmer and 4 returns, Polaris 280 pressure cleaner w/booster pump, 7 x 7 spa w/6 jets, TF-100 Test Kit w/speed stir
    Re: Converting from SWG to Chlorine pool?
    Switching from a SWG to chlorine is very easy. Cleaning up the green will be a bit more work.
    The first thing is to get a complete set of water test results so we know what we are working with.
    One little warning, trying to help out friends with their pool doesn't always work out. There is nothing you can really do about that, just be aware it is a possibility.
    May 2012
    Flower Mound, TX
    130
    Ok, thanks Jason. I'll get back with you. He's going on a trip next week, we are house sitting for one week. Maybe I will surprise him with a clean pool using the TFPC method.
    John
    38,521
    Well that would make you a very good friend if you SLAM the pool while they are gone.
    May 2014
    Houston, TX.
    23
    I need a neighbor like you! If you do take this on while he is out please do the daily picture update as well! I love a good read with pictures!
    5.455K Gal, AG Inflatable Ring Pool, Type B cartridge filter in a Intex model T633 2,500 GPH pump, Installed 09/2013, SWG.
    May 2012
    Flower Mound, TX
    130
    OK here we go! I do mean we, need your help.
    Today took pictures and chemical readings. I need to find my notes on how to load pictures again, its been awhile.
    DATE: 7 JUN
    TIME: 1830
    POOL TEMP: 85
    FC: .5
    CC: 1.5
    PH: 7.1
    TA: 100
    CH: 360
    CYA 100 - 125 (could be more)
    No longer he is using swg, it looks like he had it removed. He got tired of replacing salt water cells? He said that he thinks his chlorine dispenser is not working, but when I ran the system it was feeling up with water? He uses a large toy duck in the pool that you fill up with pucks (never saw that one coming)
    Oh, he also has a vacuum (suction) cleaner, not sure how that works. I will so some home work on loading pictures, after dinner.
    Thanks, John
    Donldson's Avatar
    NW Ohio
    2,917
    You are a heck of a friend!
    I would recommend against doing a water change without his knowledge, especially if it's city water. Getting that CYA down to at least half that would be a really good idea though. If you really want to SLAM it for him I would treat it like 130 CYA, which means 51 FC level. That's a lot of bleach for something that will just turn green again if he doesn't change his habits...
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    May 2012
    Flower Mound, TX
    130
    Thank you, I forgot to mention he did give me the go ahead to drain. That's what he was going to do when he got back. Also he mention the pool size is about 14,500 gal.
    Thanks, John
    May 2012
    Flower Mound, TX
    130
    May 2012
    Flower Mound, TX
    130
    http://i1101.photobucket.com/albums/...ps603c69c2.jpg
    Pump station. I labeled direction of flow to help me out, also where the flow is coming from.
    http://i1101.photobucket.com/albums/g439/hooksbbq/Dawson%20Pool/DawsonPool013_zpsf4efd5ef.jpg
    Can't figure this right valve out. The left valve I found out its the two skimmers. It must be from the main drains, but why have two lines, also I think he has it off.
    Sorry, been awhile since I posted pictures. Using photobucket. Any help?
    38,521
    You need IMG tags adding the url. There is a sticky in the forum issues area.
    May 2012
    Flower Mound, TX
    130
    I'm not sure what the valve does on the left, I think these two lines come from the main drain.
    Cleaner, not sure where this is tide in to pump house.
    Thanks, Jason. Now I have in puted some pictures, what do you think?
    May 2012
    Flower Mound, TX
    130
    Jason, correct me if I'm wrong.
    1) start draining. Probably 3/4 of the pool.
    2) fill pool back up
    3) use bleach or liquid chlorine
    note: I have granular shock, would that do it? if not, what should I use Liquid or bleach?
    4) run pump 24/7 and brush daily.
    note: this is the timer, not sure how to set up run all the time. I went to manual on, and it shut off?
    Note: when do I add CYA?
    Do I have to go in pool and scrub algae and stains while pool is empty, I hope not?
    38,521
    You have 3 suction lines that are likely the skimmer, the floor, and the suction cleaner port on the side of the pool.
    Liquid chlorine and bleach are the same ingredient, different strengths. You should stick with them as the granules have side effects.
    May 2013
    Bay City, Michigan
    283
    Was your original CYA test of "100 to 125 maybe more" done using the diluted test method for testing over 100?
    AS far as steps...I would think it should be more like,
    1. Drain & refill
    2 Retest CYA
    I cannot comment on if a 3/4 drain is too much or not and why are you asking when to add cya? Your draining and filling to lower CYA....adding more should be the least of your concerns unless you drain too much water. Doing the diluted water test for CYA will give a good idea where the CYA will be after you drain a certain amount.
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    May 2012
    Flower Mound, TX
    130
    Your right about the cya. I won't be concern about adding cya. I think I will use bleach, since that is what I use. I need to slam, to get rid of the algea and stains.
    May 2014
    Houston, TX
    155
    I'm following this thread, and I would love to know the reaction of your friend when he sees a sparkler in his yard upon his return!
    IG gunite pool size: 12,500 gallons - includes spa with spillover, Polaris vacuum cleaner, Ultrapure Ozonator, inline tab chlorinator that I no longer use
    Filter: Hayward Swimclear Model #4030, 4-Cartridge Filters
    Pump: Century, 2 HP with a Hayward 6060 booster pump
    Date of build: March-April 2014 *NEW* : Test kit: TF-100
    May 2012
    Flower Mound, TX
    130
    OK, pool is draining. will keep you up with pictures.
    May 2012
    Flower Mound, TX
    130
    OK, after 30 hrs draining this pool 75%, I am ready to fill it up.
    I have some questions about his pump house, with pictures.
    In normal configuration the skimmer valve should be open, which it shows. Main drain valve should be open, which makes the suction cleaner close, which it shows. Is that the correct config. for normal?
    I think he is missing an extra valve here going back to the returns. The reason that I say this, is because I tried to drain this pool with his main pump going to the front yard with that valve far Right being open. But nothing came out at the exit port near the front. Either that line is clogged or most of this water was going back to the pool at the returns, because no valve to shut that off. Interesting!
  20. Back To Top    #20
    May 2012
    Flower Mound, TX
    130
    I will post new chem. test soon. Don't think the suction cleaner works that well. So I went to loan out this robot cleaner from Robertson pool co. But it didn't work, taking it back today.
    Looking a little bit better.
